Hello.
I am using Q64 module, Open AT OS version : 6.37.0, Firmware Version: 7.47.0.
i have tried to modify functions HandleRecordCmd and fnHandlePlayCmd in pcm_record_and_play sample for record and play the AMR data in this way:
[b]static void HandleRecordCmd ( u8 Source )[/b]
RetVal = adl_audioSetOption ( RecordResourceHandle,
ADL_AUDIO_AMR_MIXED_VOICE, FALSE );
ADL_AUDIO_AMR_SPEECH_CODEC_RATE, ADL_AUDIO_AMR_RATE_5_15 );
BufferSizeListen = 14;
ADL_AUDIO_AMR_BUFFER_SIZE, BufferSizeListen );
StreamBufferListen = adl_memGet ( BufferSizeListen );
PcmBufDelete ( &ListenPlayBuffer );
/* Initialize the common buffer */
if ( PcmBufInit ( &ListenPlayBuffer, (5*50*14) ) == FALSE )
TRACE ( ( PCM_TRACE_LEVEL,
"cbAppRecordCmdHandler: fnPcmBufInit failed" ) );
/* Start listening */
RetVal = adl_audioStreamListen ( RecordResourceHandle,
ADL_AUDIO_AMR, AppListenLowIrqHandle,
AppListenHighIrqHandle, StreamBufferListen );
[b]static void fnHandlePlayCmd ( u8 AudioDestination )[/b]
RetVal = adl_audioSetOption ( PlayResourceHandle,
/* Get Buffer size for Play and initialize a buffer */
BufferSizePlay = 14;
ADL_AUDIO_AMR_BUFFER_SIZE, BufferSizePlay );
StreamBufferPlay = adl_memGet ( BufferSizePlay );
RetVal = adl_audioStreamPlay ( PlayResourceHandle,
ADL_AUDIO_AMR, AppPlayLowIrqHandle,
AppPlayHighIrqHandle, StreamBufferPlay );
Recording from the microphone is successfully, but when you try to play the recorded data is the restart of the module.
These are the traces:
2013/01/15;16:17:38:796;001;ADL;1;cbAppPlayCmdHandler: SPEAKER
2013/01/15;16:17:38:812;002;ADL;1;cbAppPlayCmdHandler: BufferSizePlay: #14
2013/01/15;16:17:39:359;001;HAC;1;ARM Data Abort caught at 0026059E, Current Task 0x1D by CP15
2013/01/15;16:17:39:375;001;RTK;1;================== RTK STATUS start ==================
2013/01/15;16:17:39:375;002;RTK;1;================== RTK STATUS end ==================
2013/01/15;16:17:41:640;006;ADL;1;Binary header at 00260000
2013/01/15;16:17:41:656;001;ADL;1;PCM_RecordAndPlay: Test Application
2013/01/15;16:17:41:656;002;ADL;1;Jan 15 2013
2013/01/15;16:17:41:656;003;ADL;1;15:04:23
Help me, please. Where there may be a bug. Or give an example of the code.
Thank you.
