Can not perform OAuth authorization for Airvantage
Management Services for remote monitoring and upgrade of AirPrime modules and AirLink gateways
Postby Jorn » Tue Apr 18, 2017 8:27 am
When my API client requests its access tokens, using an authorization code, AirVantage responds with an HTTP 500, reason given: "None".
This used to work, I can't tell what's wrong
Jorn
Has thanked: 11 times
Have thanks: 0 time
Re: Can not perform OAuth authorization for Airvantage
Postby rjacolin » Tue Apr 18, 2017 8:53 am
Hi Jorn,
Can you give us more information?
which api do you call:
  • /api/oauth/token
  • /api/oauth/authorize
and which flow:
  • authorization Code Flow.
  • The Implicit Flow
  • Resource Owner Flow
which server is being used
and when is the 500 being received? after login?
Robert
rjacolin
Has thanked: 0 time
Have thanks: 12 times
Postby Jorn » Tue Apr 18, 2017 10:15 am
Hi Robert,
Calling /api/oauth/token, Authorization Code Flow, using the european server
The 500 is received after I receive the authorization code and try to get the access tokens (by passing the authorization code to /api/oauth/token)
Jorn
Have thanks: 0 time
Postby aserrano » Thu Apr 20, 2017 12:38 pm
Hi Jorn
Can you provide the client Id you use? We have made some test on our side (with different client Id) and we cannot reproduce.
Alfredo
aserrano
Has thanked: 0 time
Have thanks: 0 time
Postby aserrano » Thu Apr 20, 2017 2:24 pm
Hi Jorn,
I think we detect the problem. We are working to fix it asap.
I'll keep you informed.
Alfredo
aserrano
Has thanked: 0 time
Have thanks: 0 time
Postby aserrano » Fri Apr 21, 2017 3:08 pm
Hi Jorn,
The issue has been fixed. Please let us know if it working back on your side.
Sorry for the inconvenience.
Alfredo Serrano
aserrano
Has thanked: 0 time
Have thanks: 0 time
Postby Jorn » Mon Apr 24, 2017 8:57 am
Hello Alfredo,
It seems to be working again, thank you very much.
Jorn
Have thanks: 0 time
Return to AirVantage Management Services
Who is online
