SL8082T CUSD USSD issue
hi everybody:
who is use sl8082t (fw:R7.50) 's cusd function.
  i use AT+CUSD command in Q24 657e  and  SL8082T R7.50
  with same a simcard ..and i change SL8082T to 2g network by AT+WWSM
 but in the Q24
 at+cusd=1,"*124#"
  +cusd:1,xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx,15
and in the sl8082t
      at+cusd=1,"*124#"
  +cusd:0,xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx,68
why it is not diffrenet …it is the issue or but in SL8082T R7.50?
thanks
I have checked the CUSD command in latest FW, and the issue is not seen…
Alex
HI REX:
what is the latest fw ?
which fw you have test it …?
thanks
test on 7.52 and 7.53 once :slight_smile:
hi alex:
about SL8082T r752 some custom use the AT+CUSD=1,"*545#" return +CUSD:4 why,.but use simcom Modem
at+cusd=1,“002A0035003400350023”,15 will return +CUSD:0,“0E04…0032”,72
can you tell me how to solve the problem?
thanks
do you have email or skype
I have tried on 7.52 and is working…
at+creg?
+CREG: 0,1
at+cusd=1,"*545#"
+CUSD: 1,“Press 1 for Sonajeeto Competition Pack
Press 2 for Desi Girls
Press 3 for Masti Pack
Press 4 for MISSU Pack
Press * for more”,15
ati3
R7.52.2.A5.201411281219.SL8084T 1804452 112814 12:19
Make sure your modem is registered to network…
-Alex
dear alex:
thanks for your reply:
i use the other ussd code *121# it have return and all is english character…
in thailand,,we use truemove network..it support english and thailand ..so if the ussd code return english ..it is ok
but if the ussd code is retrun include thailand character..it will be retrun +CUSD:4  or +CUSD:2
we try the with simcom and huawei and quectel 3g modem ...it can support AT+CSCS="UCS2"  so..the *545#  retrun is ok ,,,but our SL8082T  at+cscs do not  support AT+CSCS  's UCS2  config ..
 can you explain  ,,how the solve the issue..or need other configurate?
thanks alxe
I have done some tests… found one interesting thing…
if you disable OAT using AT!CUSTOM command, then you can use ‘UCS2’ format.
at
at+wopen?
+WOPEN: 0
at+cscs=?
+CSCS: (“GSM”,“PCCP437”,“IRA”,“HEX”)
ati9
“DWL”," C04.05.14.00.SL8RDBT R2684 CNSHZ-ED-XP0031 2015/11/05 21:36:55","",“Sier
ra Wireless”,0,"",“00000000”,“00000000”
“FW”,“FW_754_0_A1_22_1.SL808FAx”,“R7.54.0.A1.201603171313.SL8080”,“Sierra Wirele
ss”,1997208,“031716 13:13”,“a887779d”,“10002020”
“MODEM 3G+”,“Revision: C04.05.14.00.SL8RDAP R2684 CNSHZ-ED-XP0031 2015/11/05 21:
36:55”
“OAT”,“v5.56.20160607122008”,“Internet Application”,“Sierra Wireless”,282944,“06
0716 12:22”,“d30581c1”,“10700000”
-“Developer Studio”,“2.3.2.201310241753”
-“Open AT Application Framework package”,“2.54.0.A1.201603181529”
-“Open AT OS Package”,“6.54.0.A1.201511201000”
-“Firmware Package”,“7.54.0.A1.201603171313”
-“Internet Library Package”,“5.58.0.A1.201512161421”
“ROM”,“8400000”
“RAM”,“4000000”
“OATRAM”,“40000”
“DWLNAME”,“SL808xA”
at!entercnd=“A710”
at!custom?
!CUSTOM:
ISVOICEN 0x01
STKUIEN 0x02
OATENABLE 0x01
at!custom=“OATENABLE”,0
at+cscs=?
ati9
36:55”
“ROM”,“8400000”
“RAM”,“4000000”
“OATRAM”,“40000”
“DWLNAME”,“SL808xA”
at+wopen?
+WOPEN: 0
at!reset
at
at+cscs=?
+CSCS: (“IRA”,“GSM”,“UCS2”,“PCCP437”)
Hope this will help you :slight_smile:
-Alex
hi alex:
thanks for your help .
but if i disable the OAT…i can not use the SL8082T’s commnad .like AT+STSF AT+CUSD ect ?
yes… that’s a blocking point :frowning:
I found one interesting point in 3GPP spec 27.007. As per that,
Seems like this will help you :slight_smile:
-Alex
hi what is the latest fw ?
