How to run PLMN_Scan on a SL 808XT
I read in the help files that the plmn scan example is not supported on the SL 808XT chipset. Is there an alternative way to take the L3 information (no with AT commands)???
Hi
We can communicate to the module either through AT command or through Application. But the application also internally fires AT commands. So finally it’s AT commands which will come into play.
For plmn selection, you can refer AT+COPS
-Alex
