SL6087 on SL Series Development Kit
Good morning,
Hardware configuration:
We are using SL6087 on the Sierra Wireless SL Series Development Kit.
Software configuration:
Developer Studio 3.6 on Windows 10 (We could not use version 2.3 as described here http://bytefreaks.net/sierra-wireless/using-sierra-wireless-sl-series-development-kit-on-windows-10)
The problem
When we try to load any application, the IDE will execute some commands to get the status of the system.
At some point it will execute
at+wopen=9
which will result in an error
+CME ERROR: 3
From the manual I found the following description for the error
Is this problem an issue with the configuration of the board? We followed the manual on setting the latches.
How can I proceed with the upload process?
Thank you for your time.
If you check in AT command guide, you can see AT+WOPEN=9 will give you information about file system size available in your module along with OAT size. I guess your module doesn’t have file system (may be you are using old firmware or you didn’t configure that )which is leading to this error.
-Alex
