Q2687RD firmware 7.52 upgrade by XMODEM problem
SL6087, SL808x, SL809x, SL9090, SL501x, Q2686, Q2687, Q2698, Q26 Elite
Postby kamil_belter » Wed Apr 19, 2017 1:24 pm
I've tried to upgrade firmware from 7.45 to 7.52 by XMODEM-1K. Bootloader was correctly updated, but firmware update is failing. For update I'm using custom application with XMODEM-1K protocol implemented. Q2687RD cancels XMODEM-1K transmission (by CAN) after receiving ~70% of file (938 or 939 packet; packet size is 1024) and few times during firmware update application received char stream out of XMODEM-1K protocol with content:
*** XMODEM BINALLOCATION ERROR ***
I've checked that firmware 7.46 and 7.51 upgrades correctly.
I would appreciate your help in this topic.
kamil_belter
Has thanked: 0 time
Have thanks: 0 time
Re: Q2687RD firmware 7.52 upgrade by XMODEM problem
Postby kamil_belter » Thu Apr 20, 2017 5:39 am
I've found solution. There was similar problem with SL6087 mentioned in this topic: viewtopic.php?f=118&t=10238
Using WOPEN=4 command to erase the binary from memory helped with upgrade.
So my procedure was (I had firmware 7.51 installed):
1. update botloader
2. restart modem
3. check if modem response with AT
4. WOPEN=4
5. check if modem response with AT
6. "AT+WDWL"
7. send file with XMODEM
kamil_belter
Has thanked: 0 time
Have thanks: 0 time
Return to Q/SL Series
Who is online
