Hi there,
from some days I’m trying to use the QMI drivers with the MC7710 modem. Unfortunately as i can see, the product code of this modem (1199:68A3) is not listed.
Is it supported? I’ve also tried to force the module to take care of the usb device but even if it creates the ttyUSB devices, it doesn’t create any /dev/qcqmi% device.
I’m using the latest version of the QMI drivers (SierraLinuxQMIdriversS2.8N2.13).
Please I think that I may be facing similar issue. Just that in my case I think that the MODEM is in DIP mode. In windows adapter setting.My it see’s the card as ETHERNET adapter and I have tried several times to reset the modem to factory setting or update the firmware to QMI so that widows may recognise the card as cellular card.
Please how do I know the OEM password of the card? So that I can try same command you shown Salvatorenoveli. Also I will like to know if I should use 68A2 for AT!UDPID? For now I am only able to connect to the internet via AirCard Watecher
