em7565 available Documentation
Does someone know when the AT command Reference for em75xx will be available?
AirPrime EM75xx AT Command Reference (Doc# 41111748)
I can‘t find it at the webpage.
Thank you,
Michael
Michael,
It is probably going to be released when the product goes fully commercially available. Where did you get the reference from?> Its not in the PTS (and I cannot see any document attached to it on the internal systems). The EM74 series manual will provide a good starting point although some commands will have been deprecated.
When is this product expect to be commercially available?
I got the reference from the AirPrime - EM7565 - Product Technical Specification r6 (released Feb 08, 2018)
So I thought that it is somewhere available…
I have asked about when it will be available, will let you know.
We expect to have the command manual on the system mid March.
any additional information about em7565? like footprint and mechanical documentation. thanks
There is no point in supplying mechanical or foot print documentation as it is a standard form factor defined by PCISig. If you have a specific request then I will see if I can find it for you?
