For my project I am planning to use MC7455 module for LTE connection and also as GPS receiver. After powering up the system I could see that the device is getting attached. I am using Linux Kernel:4.9.39 and the build system is Yocto(Pyro).
I am planning to use connman as the connection manager. Connman uses ofono for Modem related functionalities. The versions used are: Connman: 1.34 Ofono: 1.20.
I tried to use the test scripts provided by Ofono. But after running the scripts, I am seeing that the modem is not getting identified. The log messages are as follows:
root at cl-som-imx7:/usr/lib/ofono/test# ./list-modems
root at cl-som-imx7:/usr/lib/ofono/test# ./enable-modem
Traceback (most recent call last):
File “./enable-modem”, line 14, in
path = modems[0][0]
IndexError: list index out of range
I also tried using Modemmanager , modem manager also fails to attach the device. The log messages are as follows:
cl-som-imx7 ModemManager[223]: [/dev/cdc-wdm0] Reading expected data format from: /sys/class/net/wwan0/qmi/raw_ip
cl-som-imx7 ModemManager[223]: [/dev/cdc-wdm0] Allocating new client ID…
cl-som-imx7 ModemManager[223]: [/dev/cdc-wdm0] Registered ‘wda’ (version 1.16) client with ID ‘1’
cl-som-imx7 ModemManager[223]: [/dev/cdc-wdm0] Writing expected data format to: /sys/class/net/wwan0/qmi/raw_ip
cl-som-imx7 ModemManager[223]: [/dev/cdc-wdm0] Releasing ‘wda’ client with flags ‘release-cid’…
cl-som-imx7 ModemManager[223]: [/dev/cdc-wdm0] Unregistered ‘wda’ client with ID ‘1’
cl-som-imx7 ModemManager[223]: [/dev/cdc-wdm0] Registered ‘dms’ (version 1.14) client with ID ‘2’
cl-som-imx7 ModemManager[223]: [/dev/cdc-wdm0] Registered ‘nas’ (version 1.25) client with ID ‘3’
cl-som-imx7 ModemManager[223]: [/dev/cdc-wdm0] Registered ‘wms’ (version 1.10) client with ID ‘2’
cl-som-imx7 ModemManager[223]: [/dev/cdc-wdm0] Registered ‘uim’ (version 1.45) client with ID ‘2’
cl-som-imx7 ModemManager[223]: (ttyUSB2): port attributes not fully set
cl-som-imx7 ModemManager[223]: couldn’t load list of Own Numbers: ‘Couldn’t get MSISDN: QMI protocol error (16): ‘NotProvisioned’’
cl-som-imx7 ModemManager[223]: No valid PRI+MODEM pairs found. Assuming firmware unsupported.
cl-som-imx7 ModemManager[223]: Modem: state changed (unknown -> disabled)
May I know what is the issue. I have flashed the latest MC7455 firmware.
Normally I use ofono to connect the MODEM to internet. But the ofono is not able to identify any modems.
With Modemmanager I saw some error messages,
So I thought that Modemmanager is also not able to connect to the Module.
I am seeing two different protocols :MBIM and QMI . I am confused by what should I use. I have worked previously with TELIT modems which uses QMI protocol . If I understood the technical specification, SIeraa supports both QMI and MBIM. I can change this by using the AT command " AT!USBCOMP " . The RMNET corresponds to QMI.
These are warnings, not errors.It just means that MM will list your number as ‘unknown’ and the firmware management interface will be unable. But I don’t see how that is a problem unless you were looking for those specific features.
