EM7355 GPS will not resume after standby
Is there a setting that can be placed into the configuration.ini file to keep the GPS port active during a Windows Standby event or a setting to force the GPS to reconnect? When the system comes out of Standby, the modem reconnects automatically but the GPS does not. After a Standby event, the GPS has to be cycled (disconnect/reconnect) for it to start receiving NMEA data again.
This issue has not be seen earlier ,so this problem needs a detailed technical analysis. Please contact your Technical support in Sierra Wireless to provide you the solution.
Thanks & Regards,
Moderator
