no cellular service for em7455 with window10!
I have a long pain to let my AT&T sim card work with em7455. At first, install recent em7455 driver with PC, showed and detected perfect “sierra wireless em7455” under driver manger. But no service and connection got. ATT sim card information and telephone number can be seen from mobile network property, the same issue even with skylight install ed. I guess the problem still come from EM7455. My att sim tested in ipad has service and connection. But while it put into adapter directly connect to USB port of Window10 PC, no cellar service and connection.let em7455 switch to generic FW and MBIM mode. tested again and no service still got.100% sure that em7455 is under generic FW, right ATT APN and Mibm mode. no problem to detect em7455 with device manager, every com port open, ATi communication works. . So strange!
Including the following em7455 configuration from AT commands
ATT apn is “broadband”, I put
at+cgdcont=1,“ipv4v6”,“broadband”
at+cgdcont?
Recieve: +CGDCONT: 1,“IPV4V6”,“broadband”,“0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0”,0,0,0,0
at!pcinfo?
Recieve: State: Online
Recieve: LPM voters - Temp:0, Volt:0, User:0, W_DISABLE:0, IMSWITCH:0, BIOS:0, LWM2M:0, OMADM:0, FOTA:0
Recieve: LPM persistence - None
AT!PCOFFEN?
Recieve: 0 (“0” = Modem will enter LPM (low power mode) when W_DISABLE is asserted.)
at+cgdcont=?
Recieve: +CGDCONT: (1-24),“IP”,(0-2),(0-4),(0-1),(0-1)
Recieve: +CGDCONT: (1-24),“PPP”,(0-2),(0-4),(0-1),(0-1)
Recieve: +CGDCONT: (1-24),“IPV6”,(0-2),(0-4),(0-1),(0-1)
Recieve: +CGDCONT: (1-24),“IPV4V6”,(0-2),(0-4),(0-1),(0-1)
at!gstatus?
Recieve: Current Time: 859 Temperature: 23
Recieve: Reset Counter: 1 Mode: ONLINE
Recieve: System mode: LTE PS state: Not attached
Recieve: LTE band: B13 LTE bw: 10 MHz
Recieve: LTE Rx chan: 5230 LTE Tx chan: 4294967295
Recieve: LTE CA state: NOT ASSIGNED
Recieve: EMM state: Deregistered Limited Service
Recieve: RRC state: RRC Idle
Recieve: IMS reg state: No Srv
Recieve: PCC RxM RSSI: -97 RSRP (dBm): -137
Recieve: PCC RxD RSSI: -88 RSRP (dBm): -118
Recieve: Tx Power: 0 TAC: F10A (61706)
Recieve: RSRQ (dB): -12.4 Cell ID:
Recieve: SINR (dB): 0.8
at+cfun?
Recieve: +CFUN: 1
my log showed:
Wed Jul 19 00:42:25 2017 daemon.notice netifd: wan1 (2160): swradiostate: off
looks radio didn’t turn on. don’t know why?
Which hardware have you installed ? I’ve both EM/MC7455 installed on DELL E7270/E7240 running Windows 10 Pro 64 bit/Ubuntu 17.04 without any issues. You can try taping pins #8 on EM7455.
Please do test in command prompt as below:
netsh mbn sh int
netsh mbn sh read int=*
netsh mbn sh rad int=*
netsh mbn sh cap int=*
netsh mbn sh vis int=*
Regards,
On MC7455, you have to be running “AT&T” firmware. Generic will not connect. I assume it would be the same on EM.
Technically the firmware is the same, just the PRI is different, but it has to be AT&T. I would check that first based on what you wrote.
Post your at!impref? command
Thanks for your help. My story began from getting one lenovo em7455. Following the following instruction, I tried to let it work with one non-lenovo windows 10 PC or flashed Rooter FW router that supports EM/EC7455.:
  1. put in USB adapter. install em7455 with one Thankpad laptop.
  2. Then enter these commands to change to generic and mibm mode:
    AT!ENTERCND=“A710”
    AT!USBPID=9071,9070
    AT!USBVID=1199
    AT!PRIID=“9904609”,“002.117”,“GENERIC”
    AT!IMAGE=0
    AT!RESET
    Boot back into non-lenovo windows, install Sierra Wireless generic drivers 4581 from source. sierrawireless.com, and flash with “SWI9X30C_02.24.03.00_00_GENERIC_002.021_000” firmware.
  3. set ATT APN
    looks everything prefect. But no service and connect. found windows automatically installed lenovo mobile broadband INF package to start em7455, also switch back ATT FW. Details:
Recieve: ati
Recieve: Manufacturer: Sierra Wireless, Incorporated
Recieve: Model: EM7455
Recieve: Revision: SWI9X30C_02.24.03.00 r6978 CARMD-EV-FRMWR2 2017/03/02 13:36:45
Recieve: at!priid?
Recieve: PRI Part Number: 9904609
Recieve: Revision: 002.117
Recieve: Customer: GENERIC
Recieve: Carrier PRI: 9999999_9904594_SWI9X30C_02.24.03.00_00_ATT_002.023_000
Recieve: OK
Recieve: at!impref?
Recieve: !IMPREF:
Recieve: preferred fw version: 02.24.03.00
Recieve: preferred carrier name: ATT
Recieve: preferred config name: ATT_002.023_000
Recieve: current fw version: 02.24.03.00
Recieve: current carrier name: ATT
Recieve: current config name: ATT_002.023_000
Recieve: AT!USBCOMP?
Recieve: Config Index: 1
Recieve: Config Type: 1 (Generic)
Recieve: Interface bitmask: 00001009 (diag,modem,mbim)
Recieve: OK
Recieve: at!image?
Recieve: TYPE SLOT STATUS LRU FAILURES UNIQUE_ID BUILD_ID
Recieve: FW 1 GOOD 1 0 0 ?? 02.20.03.00?
Recieve: FW 2 GOOD 2 0 0 ?? 02.24.03.00?
Recieve: FW 3 EMPTY 0 0 0
Recieve: FW 4 EMPTY 0 0 0
Recieve: Max FW images: 4
Recieve: Active FW image is at slot 2
Recieve: PRI FF GOOD 0 0 0 002.023_000 02.24.03.00_ATT
Recieve: PRI FF GOOD 0 0 0 002.021_000 02.24.03.00_GENERIC
Recieve: Max PRI images: 50
netsh mbn sh int:
get all information about em7455 except
signal : 0%
RSSI/RSCP : 0 (-113 dBm)
I will check my antenna connection? not sure if this is a reason?
netsh mbn sh read int=*:
get all info from ATT SIM
netsh mbn sh rad int=*:
Both Radio status : on
Could you check below AT commands.
AT!GSTATUS?
Believe AT!USBCOMP can be changed to USBCOMP=1,1,100D (for MBIM) or 1,1,50D (for QMI).
I just want to give some information. I’ve tested my MC7455 on DELL E7240 running win 10 64 bit for all netsh mdm related commands where result as below :
netsh mbm sh int
Signal : 0%
State : SIM not inserted
I believe same as yours. That why signal shows 0%.
Thanks again! I tested again.
Recieve: AT!GSTATUS?
Recieve: !GSTATUS:
Recieve: Current Time: 18 Temperature: 19
Recieve: LTE band: No band LTE bw: 1.4 MHz
Recieve: LTE Rx chan: 0 LTE Tx chan: 4294967295
Recieve: EMM state: Deregistered Attach Needed
Recieve: PCC RxM RSSI: 0 RSRP (dBm): 0
Recieve: PCC RxD RSSI: 0 RSRP (dBm): 0
Recieve: Tx Power: 0 TAC: 0000 (0)
Recieve: RSRQ (dB): 0.0 Cell ID: 00000000 (0)
Recieve: OK
I found : for em/ec7455 at!usbcomp=1,1,1009 (for MBIM mode just I did), at!usbcomp = 1,1,10d (for QMI) , at!usbcomp=1,1,100d (to expose the NMEA port)
i have no problem to read all information from ATT sim card (window 10 or netsh mbn sh read int=*:). But don’t know why signal zero?
looks like even though it shows LTE but “no band” was found. Below is from my MC7455 on windows 10 pro 64 bit
at!gstatus?
!GSTATUS:
Current Time: 113 Temperature: 35
LTE band: B7 LTE bw: 20 MHz
LTE Rx chan: 3150 LTE Tx chan: 21150
RRC state: RRC Idle
PCC RxM RSSI: -74 RSRP (dBm): -103
PCC RxD RSSI: -72 RSRP (dBm): -102
Tx Power: 0 TAC: 0192 (402)
RSRQ (dB): -8.6 Cell ID: 06690A15 (107547157)
SINR (dB): 19.8
These all from me and believe other members could provide more help precisely.
In my first post, I can found LTE band, but don’t know why service be limited?
at!gstatus?
Recieve: EMM state: [b]Deregistered Limited Service
Finally I fixed my no service issue. very simple, re-checked both antenna connections. tried to flash the generic ATT FW. Then, everything works well on window10 PC. Found band 12 and 2. even em7455 directly worked with my flashed Rooter router. one only problem is that the cellular signal has only 48%. maybe need better antenna. Thanks zainol69, kiltym for your help.
Hey cjtct, Did you able to increase your cellular signal? I am getting only 40% signal.I am also thinking to develop a wireless cellular camera. Don’t know it possible or not. I am looking for total guide and solution for this type problem.
Hi All.
I have a ThinkPad P50 with the same issue, EM7455 is stated as turned off.
How do i run AT commands from Win10? ?
Sorry …total noob here
Do you install the usb driver in win10?
If yes, you can use tera term to open modem port to enter
AT command
Dont think I have installed any USB drivers.
So basically i got this Lenovo P50 laptop from another person…the person just uses it for normal office stuff.
There’s a sim card slot which i found out is an EM7455 from device manager.
Inserted the SIM … and it states my network operator, but it’s greyed out and says turned off.
Tried all i can from drivers and such…and found this post!..
So yeah…total noob in this specific area. :blush:
Then go to source.sierrawireless.com to download and usb driver and skylight
Alright all done
Still the same
Skylight states radio is turned offskylight
Do you have modem port in device manager?
Nope i dont have any modem port in Device Manager
Seems to be same issue.
