MC7455 USB device disconnects immediately
I am working on an IOT product, where we are planning to use Sierra MC7455 chip as an LTE Modem and also for GNSS. We are using Yocto based build system, so I could configure the Linux Kernel and build again.
The kernel version used is 4.9.39. I have enabled the Sierra Wireless config for USB_Serial in kernel config. After turning on the system I could see that the chip keeps on connecting and disconnecting immediately. The logs are as follows:
qcserial 1-1.3:1.0: device disconnected
usb 1-1.3: new high-speed USB device number 23 using ci_hdrc
usb 1-1.3: New USB device found, idVendor=1199, idProduct=9070
usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
usb 1-1.3: Product: Sierra Wireless MC7455 Qualcomm
usb 1-1.3: Manufacturer: Sierra Wireless, Incorporated
usb 1-1.3: SerialNumber: LQ71660082041020
qcserial 1-1.3:1.0: Qualcomm USB modem converter detected
usb 1-1.3: Qualcomm USB modem converter now attached to ttyUSB0
usb 1-1.3: USB disconnect, device number 23
qcserial ttyUSB0: Qualcomm USB modem converter now disconnected from ttyUSB0
usb 1-1.3: new high-speed USB device number 24 using ci_hdrc
usb 1-1.3: USB disconnect, device number 24
Please let me know, how to solve this issue. I have libqmi installed from the Yocto build. I have also flashed the latest firmware from Sierra - 9999999_9904609_SWI9X30C_02.24.03.00_00_GENERIC_002.021_000.exe
Thanks & Regards,
Vinothkumar
Vino,
I cannot really tell you why this would be doing it but I would STRONGLY recommend that you use our GobiSerial and GobiNet drivers, the open source ones are used widely as is qmilib but they can have unpredictable behaviour which is why we have our own (and our own equivalent of qmilib).
The modem is looping in bootloader mode without ever enumerating in application mode. It’s unlikely that drivers, or any other part of the host sotware or hardware, makes any difference. The bootloader should eventually enter failsafe mode where the ramdump tool from the SDK can be used to help analyzing the crash. I recommend using SWI support for this.
I have an update. I tried to use USB to mini-PCIe convertor. Surprisingly, if I connect to my hardware using USB to mini-PCIe, the chip is getting identified and is working fine. But if I tried to connect to the PCIe slot its not working, the device gets disconnected immediately and is trying to connect again.
Not sure whats happening , do you have any suggestion.
Regards,
Vinothkumar
Vino,
Are you plugging this into a PCIe slot on a laptop? If so then the PC OEM’slock these down pretty hard as it is for their use only, it will probably be a secret setting somewhere in the BIOS. Can’t help you there.
No. I am using an embedded hardware from Compulab.
compulab.com/products/comput … /#overview
I have used the pcie slot with TELIT chips, it worked fine.
Regards,
Vinothkumar
I assume the slot on the board is configured for PCIe and not USB3 SS? Did you cover the USB3 TX/RX pins on the modem? If not, then try that.
I tried masking the USB pins (USb3 Tx and RX pins) . I have attached the image.
Still I am facing the same issue when I connect the module over PCiE. The device enters into boot mode and loops repeatedly.
usb 1-1.3: new high-speed USB device number 26 using ci_hdrc
usb 1-1.3: SerialNumber: LQ71660022021020
usb 1-1.3: USB disconnect, device number 26
Any info on the topic would be helpful.
Regards,
Vinothkumar
Vino,
I think you need to check the full pin out of the PC board you are using and compare it to the MC74 one. there may be some other incompatibility.
After lot of tries with masking the pins, I could succesfully connect the MC7455 to my system using PCIe.
I have masked the following pins:
USB3 masking -> Pin 23,25,27,29,31,33
and also the following pins:
Pin 20 - W_DIABLE_N
Pin 22 - SYSTEM_RESET_N
Pin 24 - Vcc
I am not sure why masking these pins are necessary. Any information on side effects of masking these pins would be helpful.
Regards,
Vinothkumar
Regards,
Vinoth
Vino,
If the pins are in the wrong level or the unit is detecting activity on then not consistent with USB 3.0 then it causes issues with enumeration of the unit to the host.
I am also facing this issue using the Ubuntu 22.04 Desktop version & Kernal version 6.5.0-18-generic USB 1-1.3 Qualcomm USB modem converter MC7304 & MC7430, Pls help to resolve this issue.
What usb driver have you installed?
Can you post the kernel log when connected with the module?
Hi Thanks for the reply pls following details
Feb 22 19:47:31 lamhas-pro kernel: [ 5288.774495] qcserial 1-1.3:1 .0: Qualcomm USB modem converter detected
Feb 22 19:47:31 lamhas-pro kernel: [ 5288.774600] usb 1-1.3: Qualc omm USB modem converter now attached to ttyUSB3
Feb 22 19:47:31 lamhas-pro kernel: [ 5288.774997] qcserial 1-1.3:1 .2: Qualcomm USB modem converter detected
Feb 22 19:47:31 lamhas-pro kernel: [ 5288.775056] usb 1-1.3: Qualc omm USB modem converter now attached to ttyUSB4
Feb 22 19:47:31 lamhas-pro kernel: [ 5288.775364] qcserial 1-1.3:1 .3: Qualcomm USB modem converter detected
Feb 22 19:47:31 lamhas-pro kernel: [ 5288.775428] usb 1-1.3: Qualc omm USB modem converter now attached to ttyUSB5
Feb 22 19:47:31 lamhas-pro kernel: [ 5288.775777] qmi_wwan 1-1.3:1 .8: cdc-wdm3: USB WDM device
Feb 22 19:47:31 lamhas-pro kernel: [ 5288.776136] qmi_wwan 1-1.3:1 .8 wwan2: register ‘qmi_wwan’ at usb-0000:00:1a.0-1.3, WWAN/QMI de vice, 9a:57:24:3d:ca:c1
Feb 22 19:47:31 lamhas-pro kernel: [ 5288.776557] qmi_wwan 1-1.3:1 .10: cdc-wdm4: USB WDM device
Feb 22 19:47:31 lamhas-pro kernel: [ 5288.776832] qmi_wwan 1-1.3:1 .10 wwan3: register ‘qmi_wwan’ at usb-0000:00:1a.0-1.3, WWAN/QMI d evice, 9a:57:24:3d:ca:c1
are you installing the MBPL USB driver?
https://source.sierrawireless.com/resources/airprime/software/mbpl/mbpl-software-latest/#sthash.ZXRwiiKx.pnQ5zaB5.dpbs
What is the current issue you are facing now?
Have you tried to establish data connection with the MBPL SDK?
“I am currently using Ubuntu 22.04 and I am facing an issue where my modems keep disconnecting and reconnecting frequently. I have not installed any drivers. Can you please let me know if I need to install one? If yes, what is the procedure to do so?”
you can see this document as example:
The download page showing the latest release pls guide which one need to downloads and install for these MC7304 & MC7430 modems
If you want I can also provide you the remote access of the server , pls let me know if you want have a look?
MBPL_DRIVERS_R35_ENG4-bin.tar is the USB driver
MBPL_SDK_R35_ENG4-lite.bin.tar is the SDK
BTW, have you read the document?
