Win 10 Sleep issue with 7355
I have a panasonic toughpad FZ-G1 with a 7355 module with onboard GPS running Win 10 64 bit. After the device is woken back up after a Sleep, any application that was running and accessing the GPS including GPSViewer or any custom built app is having to be restarted to reconnect to the NMEA Stream via the USB Serial Port. Any suggestions to overcome this issue?
Can you please once check with panasonic official support, as this issue is not seen on other Win 10 64 bit machines.
Thanks & Regards,
Moderator
Try to go to device manager and the GPS port, then do not let windows power it off during sleep
