Dear Forum,
I originally purchased an MC7354 pre-configured for use with Verizon Wireless. However, after fighting Verizon for a week I am now fed up enough to go with another carrier, AT&T to be exact, and was wondering if I needed to change firmware versions to do so. I am using an MC7354 configured from the factory to work with Verizon. Additionally I am using a gateworks ventanna board and openwrt for my work. I read this article http://ftp1.digi.com/support/documentation/QN_39_Carrier_Switching_with_MC7354.pdf which says I only need to access the modem at /dev/cdc-wdm1 instead of /dev/cdc-wmd0. Additionally, that the same firmware version is used for AT&T and Verizon. Can anyone confirm this is true? I am still unable to register and connect to an AT&T tower, but that could be because I do not have antennas attached… I will include the output from a few libqmi commands below:
cat /etc/config/network
config interface 'loopback'
option ifname 'lo'
option proto 'static'
option ipaddr '127.0.0.1'
option netmask '255.0.0.0'
config globals 'globals'
option ula_prefix 'fd92:e868:6df7::/48'
config interface 'lan'
option type 'bridge'
option ifname 'eth0'
option ipaddr '192.168.1.1'
option netmask '255.255.255.0'
option ip6assign '60'
config interface 'wan'
option ifname 'wwan1'
option proto 'qmi'
option service 'cdma'
option delay '90'
option ifnanme 'wwan1'
option apn 'ISP.CINGULAR'
option device '/dev/cdc-wdm1'
root@OpenWrt:/# ifconfig
br-lan Link encap:Ethernet HWaddr 00:D0:12:A2:F0:11
inet addr:192.168.1.1 Bcast:192.168.1.255 Mask:255.255.255.0
inet6 addr: fd92:e868:6df7::1/60 Scope:Global
UP BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
eth0 Link encap:Ethernet HWaddr 00:D0:12:A2:F0:11
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:128 errors:0 dropped:0 overruns:0 frame:0
TX packets:128 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:9376 (9.1 KiB) TX bytes:9376 (9.1 KiB)
root@OpenWrt:/# uqmi -s -d /dev/cdc-wdm1 --get-pin-status
{"pin1_status":"disabled","pin1_verify_tries":3,"pin1_unblock_tries":10,"pin2_status":"not_verified","pin 2_verify_tries":3,"pin2_unblock_tries":10}
root@OpenWrt:/# uqmi -s -d /dev/cdc-wdm0 --get-pin-status
root@OpenWrt:/# uqmi -s -d /dev/cdc-wdm1 --get-serving-system
{"registration":"not_registered"}
root@OpenWrt:/# uqmi -s -d /dev/cdc-wdm0 --get-serving-system
root@OpenWrt:/# uqmi -s -d /dev/cdc-wdm0 --get-data-status
"disconnected"
root@OpenWrt:/# uqmi -s -d /dev/cdc-wdm1 --get-data-status
"disconnected"
root@OpenWrt:/# logread | grep qmi
Thu Jun 23 22:46:45 2016 kern.info kernel: [ 32.441160] qmi_wwan 1-1:1.8: cdc-wdm0: USB WDM device
Thu Jun 23 22:46:45 2016 kern.info kernel: [ 32.447087] qmi_wwan 1-1:1.8 wwan0: register 'qmi_wwan' at usb-ci_hdrc.1-1, WWAN/QMI device, 86:bc:60:41:ef:12
Thu Jun 23 22:46:45 2016 kern.info kernel: [ 32.457766] qmi_wwan 1-1:1.10: cdc-wdm1: USB WDM device
Thu Jun 23 22:46:45 2016 kern.info kernel: [ 32.463774] qmi_wwan 1-1:1.10 wwan1: register 'qmi_wwan' at usb-ci_hdrc.1-1, WWAN/QMI device, 86:bc:60:41:ef:12
Thu Jun 23 22:46:45 2016 kern.info kernel: [ 32.474061] usbcore: registered new interface driver qmi_ww an
