MC7304 - AT!DALGRXAGC Reboots modem
I’m here again with a new problem (maybe not).
I’m trying to validate the main RF path using the factory test mode.
I want to put the device in Rx mode to read a RF Generator generated wave at a given power. If the power I read on the modem is similar to the wave power, it passes, else it fails.
I do the following :
AT!ENTERCND=“A710”
AT!DAFTMACT
AT!DASBAND=47
AT!DASCHAN=21450
But when I finally issue the command : AT!DALGRXAGC? the modem reboots, while I expected it to return the AGC value.
Did I miss something?
Thank you for support!
Gregoire
I tried at my end and I am facing reboot of module after at!daschan command !. Can you please confirm at your end that your module reboots just after at!DALGRXAGC? command not before that by waiting somtime after giving each command.
Rex
