EM7455 GPS not available with SWI9X30C_02.24.03.00
this is:
Model: EM7455
Revision: SWI9X30C_02.24.03.00 r6978 CARMD-EV-FRMWR2 2017/03/02 13:36:45
AT!GOBIIMPREF?
!GOBIIMPREF:
 preferred fw version:    02.24.03.00
 preferred carrier name:  GENERIC
 preferred config name:   GENERIC_002.021_000
 current fw version:      02.24.03.00
 current carrier name:    GENERIC
 current config name:     GENERIC_002.021_000
tested with DM,NMEA,AT,MBIM und DM,NMEA,AT,QMI mode.
AT!CUSTOM?
!CUSTOM:
             GPSENABLE          0x01
             GPSSEL             0x01
             IPV6ENABLE         0x01
             SIMLPM             0x02
             USBSERIALENABLE    0x01
             FASTENUMEN         0x01
             SINGLEAPNSWITCH    0x01
GPSSEL is set to AUX antenna, GPSENABLE is also enabled.
AT!GPSAUTOSTART?
  function:  2
  fixtype: 1
  maxtime: 180 seconds
  maxdist: 50 meters
  fixrate: 1 seconds
function is not documented in AT Command Reference 4118014.
Even with AT!GPSFIX=1,60,100 and clear view to the sky I do not get a fix:
AT!GPSSTATUS?
Current time: 1980 01 06 6 00:17:52
1980 01 06 6 00:00:00 Last Fix Status    = FAIL,  FAILCODE = 0
1980 01 06 6 00:00:00 Fix Session Status = FAIL,  FAILCODE = 0
No TTFF available
AT!GPSLOC?
Not Available
Also GPSNMEA is documented, but seems not to be available in my current firmware:
AT!GPSNMEA?
!GPSNMEA: NOT IMPLEMENTED
Although setting/retrieving NMEA config works:
AT!GPSNMEACONFIG=1,1
AT!GPSNMEASENTENCE?
!GPSNMEASENTENCE: 0x3F
Any clue on how to enable NMEA output?
Cheers,
Dominik
echo \$GPS_START >/dev/ttyUSB1
where /dev/ttyUSB1 is your NMEA serial port
Oh well. I must have overlooked that. Thank you! It’s now working :slight_smile:
How can I stop the Windows drivers from installing instead of the Sierra Wireless drivers?
