Update Firmware EM7305 and Windows 10 Version 1703
when i try to Update the Firmware of the EM7305 (i has downloaded the Package Build4544), i get errors:
FDT version: 5.0.1501.1
Checking modem mode …
Disabling selective suspend …
Switching device to boot & hold mode …
Switching device to streaming mode …
Verifying image file …
Downloading firmware …
Flashing firmware …
Resetting device …
Firmware download failed.
Primary error code: 84 - Failed in checking FW update status.
Secondary error code: 84 - Failed in checking FW update status.
Device error code: 0x0 - Successful.
Final firmware update failure report - Result code: 0x0
Details - Image type: 0xff, Ref data: 0xffffffff, Ref string:
Total time elapsed: 213515 ms.
We have tested this with 9999999_9903271_SWI9X15C_05.05.61.00_00_VODA-EU_005.024_000-field.exe.
With other Firmware from the same package we get the same error.
Is there a newer Firmware available, that we can use under Windows 10 (Version 1703, Build 15063)
Or is there a other way, to update the Firmware, when we use the new Windows 10 Version?
Best regards,
Eberhard
have anywhere from Sierra Wireless has informations for me about this problem?
Best regards,
Eberhard
Again: Can anywhere help from Sierra Wireless?
Best regards,
Eberhard
Best regards,
Eberhard
Can you please mention the steps that you are following to update the FW.
Thanks & Regards,
Rex
i have started Windows 10, started a command line as administrator and run the Firmware-Update:
On the beginning of my post is the output of this command and the error.
The same happens with other Firmware-Versions for other providers, for example:
9999999_9902674_SWI9X15C_05.05.67.00_00_GENEU-4G_005.028_000-field.exe
Best regards,
Eberhard
