EM7455 - Unable to connect using linux on Thinkpad X1C5
I’ve been trying to get the EM7455 in my 5th generation X1 Carbon working on Linux (Nixos) for the last few days but I haven’t had much luck. The card worked perfectly in the stock Windows 10 before I switched over to Linux. I’m using ModemManager 1.6.2, Libmbim 1.14.0 and Libqmi 1.16.0 on Kernel 4.9.13. I’ve put the output of a bunch of commands below but to be honest, I don’t really know what I’m doing! any help would be greatly appreciated!
thip@Knuth ~> lsusb | grep Sierra
Bus 001 Device 009: ID 1199:9079 Sierra Wireless, Inc.
thip@Knuth ~> lsmod | grep cdc
cdc_mbim               16384  0
cdc_wdm                20480  2 cdc_mbim
cdc_ncm                32768  1 cdc_mbim
usbnet                 36864  2 cdc_mbim,cdc_ncm
usbcore               208896  12 usbnet,uvcvideo,cdc_mbim,qcserial,cdc_ncm,cdc_wdm,usbserial,xhci_pci,btusb,usb_wwan,xhci_hcd
thip@Knuth ~> mmcli -L
Found 1 modems:
	/org/freedesktop/ModemManager1/Modem/0 [Sierra] MBIM [1199:9079]
thip@Knuth ~> sudo mmcli -m 0 -v --set-power-state-on
[22 Mar 2017, 21:05:21] [Debug] ModemManager process found at ':1.41'
[22 Mar 2017, 21:05:21] [Debug] Assuming '0' is the modem index
[22 Mar 2017, 21:05:21] [Debug] Modem found at '/org/freedesktop/ModemManager1/Modem/0'
[22 Mar 2017, 21:05:21] [Debug] Synchronously setting full power...
error: couldn't set new power state in the modem: 'GDBus.Error:org.freedesktop.libmbim.Error.Status.Failure: Failure'
thip@Knuth ~> sudo qmicli -p -d /dev/cdc-wdm0 --device-open-mbim --dms-set-fcc-authentication
error: couldn't create client for the 'dms' service: CID allocation failed in the CTL client: Device must be open to send commands
thip@Knuth ~> mmcli -m 0 -v --simple-connect="apn=three.co.uk"
[22 Mar 2017, 21:08:18] [Debug] Forcing request to be run asynchronously
[22 Mar 2017, 21:08:18] [Debug] Assuming '0' is the modem index
[22 Mar 2017, 21:08:18] [Debug] ModemManager process found at ':1.41'
[22 Mar 2017, 21:08:18] [Debug] Modem found at '/org/freedesktop/ModemManager1/Modem/0'
[22 Mar 2017, 21:08:18] [Debug] Asynchronously connecting the modem...
error: couldn't connect the modem: 'GDBus.Error:org.freedesktop.libmbim.Error.Status.Failure: Failure'
thip@Knuth ~> sudo ModemManager --debug
ModemManager[6189]: <info>  [1490218303.166071] [main.c:158] main(): ModemManager (version 1.6.2) starting in system bus...
ModemManager[6189]: <debug> [1490218303.166703] [mm-sleep-monitor.c:245] mm_sleep_monitor_get(): create MMSleepMonitor singleton (0x1566090)
ModemManager[6189]: <debug> [1490218303.167750] [main.c:83] bus_acquired_cb(): Bus acquired, creating manager...
ModemManager[6189]: <debug> [1490218303.168715] [mm-plugin-manager.c:1559] load_plugins(): [plugin manager] looking for plugins in '/nix/store/0kflga8qxz1qqi3q3s4rvsvghyp5p24f-ModemManager-1.6.2/lib/ModemManager'
ModemManager[6189]: <debug> [1490218303.169194] [mm-plugin-manager.c:1584] load_plugins(): [plugin manager] loaded plugin 'Option High-Speed'
ModemManager[6189]: <debug> [1490218303.169366] [mm-plugin-manager.c:1584] load_plugins(): [plugin manager] loaded plugin 'Nokia'
ModemManager[6189]: <debug> [1490218303.169560] [mm-plugin-manager.c:1584] load_plugins(): [plugin manager] loaded plugin 'X22X'
ModemManager[6189]: <debug> [1490218303.169743] [mm-plugin-manager.c:1584] load_plugins(): [plugin manager] loaded plugin 'Longcheer'
ModemManager[6189]: <debug> [1490218303.169944] [mm-plugin-manager.c:1584] load_plugins(): [plugin manager] loaded plugin 'Iridium'
ModemManager[6189]: <debug> [1490218303.170284] [mm-plugin-manager.c:1584] load_plugins(): [plugin manager] loaded plugin 'Samsung'
ModemManager[6189]: <debug> [1490218303.170451] [mm-plugin-manager.c:1584] load_plugins(): [plugin manager] loaded plugin 'Via CBP7'
ModemManager[6189]: <debug> [1490218303.170655] [mm-plugin-manager.c:1584] load_plugins(): [plugin manager] loaded plugin 'Wavecom'
ModemManager[6189]: <debug> [1490218303.170964] [mm-plugin-manager.c:1584] load_plugins(): [plugin manager] loaded plugin 'Telit'
ModemManager[6189]: <debug> [1490218303.171260] [mm-plugin-manager.c:1584] load_plugins(): [plugin manager] loaded plugin 'Altair LTE'
ModemManager[6189]: <debug> [1490218303.171421] [mm-plugin-manager.c:1584] load_plugins(): [plugin manager] loaded plugin 'Linktop'
ModemManager[6189]: <debug> [1490218303.171606] [mm-plugin-manager.c:1584] load_plugins(): [plugin manager] loaded plugin 'MTK'
ModemManager[6189]: <debug> [1490218303.172024] [mm-plugin-manager.c:1584] load_plugins(): [plugin manager] loaded plugin 'Dell'
ModemManager[6189]: <debug> [1490218303.172298] [mm-plugin-manager.c:1584] load_plugins(): [plugin manager] loaded plugin 'Option'
ModemManager[6189]: <debug> [1490218303.172470] [mm-plugin-manager.c:1584] load_plugins(): [plugin manager] loaded plugin 'AnyDATA'
ModemManager[6189]: <debug> [1490218303.172714] [mm-plugin-manager.c:1584] load_plugins(): [plugin manager] loaded plugin 'Thuraya'
ModemManager[6189]: <debug> [1490218303.172953] [mm-plugin-manager.c:1584] load_plugins(): [plugin manager] loaded plugin 'Novatel LTE'
ModemManager[6189]: <debug> [1490218303.173368] [mm-plugin-manager.c:1584] load_plugins(): [plugin manager] loaded plugin 'ZTE'
ModemManager[6189]: <debug> [1490218303.173669] [mm-plugin-manager.c:1584] load_plugins(): [plugin manager] loaded plugin 'Novatel'
ModemManager[6189]: <debug> [1490218303.174012] [mm-plugin-manager.c:1584] load_plugins(): [plugin manager] loaded plugin 'Cinterion'
ModemManager[6189]: <debug> [1490218303.174150] [mm-plugin-manager.c:1584] load_plugins(): [plugin manager] loaded plugin 'Haier'
ModemManager[6189]: <debug> [1490218303.174289] [mm-plugin-manager.c:1584] load_plugins(): [plugin manager] loaded plugin 'Motorola'
ModemManager[6189]: <debug> [1490218303.174476] [mm-plugin-manager.c:1584] load_plugins(): [plugin manager] loaded plugin 'SimTech'
ModemManager[6189]: <debug> [1490218303.174876] [mm-plugin-manager.c:1584] load_plugins(): [plugin manager] loaded plugin 'Nokia (Icera)'
ModemManager[6189]: <debug> [1490218303.175351] [mm-plugin-manager.c:1584] load_plugins(): [plugin manager] loaded plugin 'Huawei'
ModemManager[6189]: <debug> [1490218303.175542] [mm-plugin-manager.c:1584] load_plugins(): [plugin manager] loaded plugin 'Pantech'
ModemManager[6189]: <debug> [1490218303.175669] [mm-plugin-manager.c:1584] load_plugins(): [plugin manager] loaded plugin 'Generic'
ModemManager[6189]: <debug> [1490218303.176133] [mm-plugin-manager.c:1584] load_plugins(): [plugin manager] loaded plugin 'Sierra (legacy)'
ModemManager[6189]: <debug> [1490218303.176273] [mm-plugin-manager.c:1584] load_plugins(): [plugin manager] loaded plugin 'Sierra'
ModemManager[6189]: <debug> [1490218303.176737] [mm-plugin-manager.c:1584] load_plugins(): [plugin manager] loaded plugin 'Ericsson MBM'
ModemManager[6189]: <debug> [1490218303.176753] [mm-plugin-manager.c:1609] load_plugins(): [plugin manager] successfully loaded 30 plugins
ModemManager[6189]: <debug> [1490218303.177321] [main.c:105] name_acquired_cb(): Service name 'org.freedesktop.ModemManager1' was acquired
ModemManager[6189]: <debug> [1490218303.177340] [mm-base-manager.c:498] mm_base_manager_start(): Starting automatic device scan...
ModemManager[6189]: <debug> [1490218303.180444] [mm-base-manager.c:537] mm_base_manager_start(): Finished device scan...
ModemManager[6189]: <debug> [1490218303.180528] [mm-sleep-monitor.c:108] take_inhibitor(): [sleep-monitor] taking systemd sleep inhibitor
ModemManager[6189]: <debug> [1490218303.180784] [mm-base-manager.c:388] device_added(): (tty/ttyS0): port's parent platform driver is not whitelisted
ModemManager[6189]: <debug> [1490218303.180901] [mm-base-manager.c:388] device_added(): (tty/ttyS1): port's parent platform driver is not whitelisted
ModemManager[6189]: <debug> [1490218303.180982] [mm-base-manager.c:388] device_added(): (tty/ttyS2): port's parent platform driver is not whitelisted
ModemManager[6189]: <debug> [1490218303.181060] [mm-base-manager.c:388] device_added(): (tty/ttyS3): port's parent platform driver is not whitelisted
ModemManager[6189]: <debug> [1490218303.181684] [mm-plugin-manager.c:1442] mm_plugin_manager_device_support_check(): [plugin manager] task 0: new support task for device: /sys/devices/pci0000:00/0000:00:14.0/usb1/1-6
ModemManager[6189]: <debug> [1490218303.181737] [mm-plugin-manager.c:1167] device_context_port_grabbed(): [plugin manager] task 0: port grabbed: wwp0s20f0u6i12
ModemManager[6189]: <debug> [1490218303.181749] [mm-plugin-manager.c:1192] device_context_port_grabbed(): [plugin manager] task 0,wwp0s20f0u6i12: new support task for port
ModemManager[6189]: <debug> [1490218303.181755] [mm-plugin-manager.c:1197] device_context_port_grabbed(): [plugin manager) task 0,wwp0s20f0u6i12: deferred until min wait time elapsed
ModemManager[6189]: <debug> [1490218303.181883] [mm-plugin-manager.c:1442] mm_plugin_manager_device_support_check(): [plugin manager] task 1: new support task for device: /sys/devices/pci0000:00/0000:00:1c.2/0000:04:00.0
ModemManager[6189]: <debug> [1490218303.181918] [mm-plugin-manager.c:1167] device_context_port_grabbed(): [plugin manager] task 1: port grabbed: wlp4s0
ModemManager[6189]: <debug> [1490218303.181927] [mm-plugin-manager.c:1192] device_context_port_grabbed(): [plugin manager] task 1,wlp4s0: new support task for port
ModemManager[6189]: <debug> [1490218303.181933] [mm-plugin-manager.c:1197] device_context_port_grabbed(): [plugin manager) task 1,wlp4s0: deferred until min wait time elapsed
ModemManager[6189]: <debug> [1490218303.182053] [mm-plugin-manager.c:1442] mm_plugin_manager_device_support_check(): [plugin manager] task 2: new support task for device: /sys/devices/pci0000:00/0000:00:1f.6
ModemManager[6189]: <debug> [1490218303.182085] [mm-plugin-manager.c:1167] device_context_port_grabbed(): [plugin manager] task 2: port grabbed: enp0s31f6
ModemManager[6189]: <debug> [1490218303.182094] [mm-plugin-manager.c:1192] device_context_port_grabbed(): [plugin manager] task 2,enp0s31f6: new support task for port
ModemManager[6189]: <debug> [1490218303.182100] [mm-plugin-manager.c:1197] device_context_port_grabbed(): [plugin manager) task 2,enp0s31f6: deferred until min wait time elapsed
ModemManager[6189]: <debug> [1490218303.182309] [mm-plugin-manager.c:1167] device_context_port_grabbed(): [plugin manager] task 0: port grabbed: cdc-wdm0
ModemManager[6189]: <debug> [1490218303.182321] [mm-plugin-manager.c:1192] device_context_port_grabbed(): [plugin manager] task 0,cdc-wdm0: new support task for port
ModemManager[6189]: <debug> [1490218303.182327] [mm-plugin-manager.c:1197] device_context_port_grabbed(): [plugin manager) task 0,cdc-wdm0: deferred until min wait time elapsed
ModemManager[6189]: <debug> [1490218303.182342] [mm-sleep-monitor.c:97] inhibit_done(): [sleep-monitor] inhibitor fd is 10
ModemManager[6189]: <debug> [1490218304.683983] [mm-plugin-manager.c:1110] device_context_min_wait_time_elapsed(): [plugin manager] task 0: min wait time elapsed
ModemManager[6189]: <debug> [1490218304.684035] [mm-plugin.c:212] apply_pre_probing_filters(): (Option High-Speed) [cdc-wdm0] filtered by subsystem
ModemManager[6189]: <debug> [1490218304.684050] [mm-plugin.c:212] apply_pre_probing_filters(): (Nokia) [cdc-wdm0] filtered by subsystem
ModemManager[6189]: <debug> [1490218304.684058] [mm-plugin.c:310] apply_pre_probing_filters(): (X22X) [cdc-wdm0] filtered by implicit MBIM driver
ModemManager[6189]: <debug> [1490218304.684102] [mm-plugin.c:212] apply_pre_probing_filters(): (Longcheer) [cdc-wdm0] filtered by subsystem
ModemManager[6189]: <debug> [1490218304.684196] [mm-plugin.c:212] apply_pre_probing_filters(): (Iridium) [cdc-wdm0] filtered by subsystem
ModemManager[6189]: <debug> [1490218304.684249] [mm-plugin.c:212] apply_pre_probing_filters(): (Samsung) [cdc-wdm0] filtered by subsystem
ModemManager[6189]: <debug> [1490218304.684281] [mm-plugin.c:212] apply_pre_probing_filters(): (Via CBP7) [cdc-wdm0] filtered by subsystem
ModemManager[6189]: <debug> [1490218304.684287] [mm-plugin.c:212] apply_pre_probing_filters(): (Wavecom) [cdc-wdm0] filtered by subsystem
ModemManager[6189]: <debug> [1490218304.684293] [mm-plugin.c:212] apply_pre_probing_filters(): (Telit) [cdc-wdm0] filtered by subsystem
ModemManager[6189]: <debug> [1490218304.684298] [mm-plugin.c:212] apply_pre_probing_filters(): (Altair LTE) [cdc-wdm0] filtered by subsystem
ModemManager[6189]: <debug> [1490218304.684304] [mm-plugin.c:212] apply_pre_probing_filters(): (Linktop) [cdc-wdm0] filtered by subsystem
ModemManager[6189]: <debug> [1490218304.684309] [mm-plugin.c:212] apply_pre_probing_filters(): (MTK) [cdc-wdm0] filtered by subsystem
ModemManager[6189]: <debug> [1490218304.684338] [mm-plugin.c:376] apply_pre_probing_filters(): (Dell) [cdc-wdm0] filtered by vendor/product IDs
ModemManager[6189]: <debug> [1490218304.684391] [mm-plugin.c:212] apply_pre_probing_filters(): (Option) [cdc-wdm0] filtered by subsystem
ModemManager[6189]: <debug> [1490218304.684442] [mm-plugin.c:310] apply_pre_probing_filters(): (AnyDATA) [cdc-wdm0] filtered by implicit MBIM driver
ModemManager[6189]: <debug> [1490218304.684518] [mm-plugin.c:212] apply_pre_probing_filters(): (Thuraya) [cdc-wdm0] filtered by subsystem
ModemManager[6189]: <debug> [1490218304.684525] [mm-plugin.c:212] apply_pre_probing_filters(): (Novatel LTE) [cdc-wdm0] filtered by subsystem
ModemManager[6189]: <debug> [1490218304.684531] [mm-plugin.c:376] apply_pre_probing_filters(): (ZTE) [cdc-wdm0] filtered by vendor/product IDs
ModemManager[6189]: <debug> [1490218304.684536] [mm-plugin.c:310] apply_pre_probing_filters(): (Novatel) [cdc-wdm0] filtered by implicit MBIM driver
ModemManager[6189]: <debug> [1490218304.684542] [mm-plugin.c:310] apply_pre_probing_filters(): (Cinterion) [cdc-wdm0] filtered by implicit MBIM driver
ModemManager[6189]: <debug> [1490218304.684548] [mm-plugin.c:212] apply_pre_probing_filters(): (Haier) [cdc-wdm0] filtered by subsystem
ModemManager[6189]: <debug> [1490218304.684554] [mm-plugin.c:212] apply_pre_probing_filters(): (Motorola) [cdc-wdm0] filtered by subsystem
ModemManager[6189]: <debug> [1490218304.684593] [mm-plugin.c:310] apply_pre_probing_filters(): (SimTech) [cdc-wdm0] filtered by implicit MBIM driver
ModemManager[6189]: <debug> [1490218304.684644] [mm-plugin.c:212] apply_pre_probing_filters(): (Nokia (Icera)) [cdc-wdm0] filtered by subsystem
ModemManager[6189]: <debug> [1490218304.684697] [mm-plugin.c:376] apply_pre_probing_filters(): (Huawei) [cdc-wdm0] filtered by vendor/product IDs
ModemManager[6189]: <debug> [1490218304.684753] [mm-plugin.c:310] apply_pre_probing_filters(): (Pantech) [cdc-wdm0] filtered by implicit MBIM driver
ModemManager[6189]: <debug> [1490218304.684759] [mm-plugin.c:212] apply_pre_probing_filters(): (Sierra (legacy)) [cdc-wdm0] filtered by subsystem
ModemManager[6189]: <debug> [1490218304.684768] [mm-plugin-manager.c:599] port_context_run(): [plugin manager] task 0,cdc-wdm0: found '2' plugins to try
ModemManager[6189]: <debug> [1490218304.684775] [mm-plugin-manager.c:622] port_context_run(): [plugin manager] task 0,cdc-wdm0: will try with plugin 'Sierra'
ModemManager[6189]: <debug> [1490218304.684780] [mm-plugin-manager.c:622] port_context_run(): [plugin manager] task 0,cdc-wdm0: will try with plugin 'Generic'
ModemManager[6189]: <debug> [1490218304.684813] [mm-plugin-manager.c:635] port_context_run(): [plugin manager) task 0,cdc-wdm0: started
ModemManager[6189]: <debug> [1490218304.684863] [mm-plugin-manager.c:519] port_context_next(): [plugin manager] task 0,cdc-wdm0: checking with plugin 'Sierra'
ModemManager[6189]: <debug> [1490218304.684997] [mm-plugin.c:804] mm_plugin_supports_port(): (Sierra) [cdc-wdm0] probe required: 'mbim'
ModemManager[6189]: <debug> [1490218304.685004] [mm-port-probe.c:1377] mm_port_probe_run(): (usbmisc/cdc-wdm0) launching port probing: 'mbim'
ModemManager[6189]: <debug> [1490218304.685014] [mm-plugin.c:264] apply_pre_probing_filters(): (Option High-Speed) [wwp0s20f0u6i12] filtered by drivers
ModemManager[6189]: <debug> [1490218304.685070] [mm-plugin.c:212] apply_pre_probing_filters(): (Nokia) [wwp0s20f0u6i12] filtered by subsystem
ModemManager[6189]: <debug> [1490218304.685076] [mm-plugin.c:310] apply_pre_probing_filters(): (X22X) [wwp0s20f0u6i12] filtered by implicit MBIM driver
ModemManager[6189]: <debug> [1490218304.685126] [mm-plugin.c:212] apply_pre_probing_filters(): (Longcheer) [wwp0s20f0u6i12] filtered by subsystem
ModemManager[6189]: <debug> [1490218304.685176] [mm-plugin.c:212] apply_pre_probing_filters(): (Iridium) [wwp0s20f0u6i12] filtered by subsystem
ModemManager[6189]: <debug> [1490218304.685241] [mm-plugin.c:310] apply_pre_probing_filters(): (Samsung) [wwp0s20f0u6i12] filtered by implicit MBIM driver
ModemManager[6189]: <debug> [1490218304.685246] [mm-plugin.c:212] apply_pre_probing_filters(): (Via CBP7) [wwp0s20f0u6i12] filtered by subsystem
ModemManager[6189]: <debug> [1490218304.685252] [mm-plugin.c:212] apply_pre_probing_filters(): (Wavecom) [wwp0s20f0u6i12] filtered by subsystem
ModemManager[6189]: <debug> [1490218304.685259] [mm-plugin.c:212] apply_pre_probing_filters(): (Telit) [wwp0s20f0u6i12] filtered by subsystem
ModemManager[6189]: <debug> [1490218304.685265] [mm-plugin.c:310] apply_pre_probing_filters(): (Altair LTE) [wwp0s20f0u6i12] filtered by implicit MBIM driver
ModemManager[6189]: <debug> [1490218304.685271] [mm-plugin.c:212] apply_pre_probing_filters(): (Linktop) [wwp0s20f0u6i12] filtered by subsystem
ModemManager[6189]: <debug> [1490218304.685277] [mm-plugin.c:212] apply_pre_probing_filters(): (MTK) [wwp0s20f0u6i12] filtered by subsystem
ModemManager[6189]: <debug> [1490218304.685282] [mm-plugin.c:376] apply_pre_probing_filters(): (Dell) [wwp0s20f0u6i12] filtered by vendor/product IDs
ModemManager[6189]: <debug> [1490218304.685324] [mm-plugin.c:212] apply_pre_probing_filters(): (Option) [wwp0s20f0u6i12] filtered by subsystem
ModemManager[6189]: <debug> [1490218304.685376] [mm-plugin.c:310] apply_pre_probing_filters(): (AnyDATA) [wwp0s20f0u6i12] filtered by implicit MBIM driver
ModemManager[6189]: <debug> [1490218304.685427] [mm-plugin.c:212] apply_pre_probing_filters(): (Thuraya) [wwp0s20f0u6i12] filtered by subsystem
ModemManager[6189]: <debug> [1490218304.685485] [mm-plugin.c:310] apply_pre_probing_filters(): (Novatel LTE) [wwp0s20f0u6i12] filtered by implicit MBIM driver
ModemManager[6189]: <debug> [1490218304.685491] [mm-plugin.c:376] apply_pre_probing_filters(): (ZTE) [wwp0s20f0u6i12] filtered by vendor/product IDs
ModemManager[6189]: <debug> [1490218304.685501] [mm-plugin.c:310] apply_pre_probing_filters(): (Novatel) [wwp0s20f0u6i12] filtered by implicit MBIM driver
ModemManager[6189]: <debug> [1490218304.685508] [mm-plugin.c:310] apply_pre_probing_filters(): (Cinterion) [wwp0s20f0u6i12] filtered by implicit MBIM driver
ModemManager[6189]: <debug> [1490218304.685514] [mm-plugin.c:212] apply_pre_probing_filters(): (Haier) [wwp0s20f0u6i12] filtered by subsystem
ModemManager[6189]: <debug> [1490218304.685520] [mm-plugin.c:212] apply_pre_probing_filters(): (Motorola) [wwp0s20f0u6i12] filtered by subsystem
ModemManager[6189]: <debug> [1490218304.685526] [mm-plugin.c:310] apply_pre_probing_filters(): (SimTech) [wwp0s20f0u6i12] filtered by implicit MBIM driver
ModemManager[6189]: <debug> [1490218304.685579] [mm-plugin.c:310] apply_pre_probing_filters(): (Nokia (Icera)) [wwp0s20f0u6i12] filtered by implicit MBIM driver
ModemManager[6189]: <debug> [1490218304.685628] [mm-plugin.c:376] apply_pre_probing_filters(): (Huawei) [wwp0s20f0u6i12] filtered by vendor/product IDs
ModemManager[6189]: <debug> [1490218304.685678] [mm-plugin.c:310] apply_pre_probing_filters(): (Pantech) [wwp0s20f0u6i12] filtered by implicit MBIM driver
ModemManager[6189]: <debug> [1490218304.685731] [mm-plugin.c:264] apply_pre_probing_filters(): (Sierra (legacy)) [wwp0s20f0u6i12] filtered by drivers
ModemManager[6189]: <debug> [1490218304.685738] [mm-plugin-manager.c:599] port_context_run(): [plugin manager] task 0,wwp0s20f0u6i12: found '2' plugins to try
ModemManager[6189]: <debug> [1490218304.685744] [mm-plugin-manager.c:622] port_context_run(): [plugin manager] task 0,wwp0s20f0u6i12: will try with plugin 'Sierra'
ModemManager[6189]: <debug> [1490218304.685750] [mm-plugin-manager.c:622] port_context_run(): [plugin manager] task 0,wwp0s20f0u6i12: will try with plugin 'Generic'
ModemManager[6189]: <debug> [1490218304.685758] [mm-plugin-manager.c:635] port_context_run(): [plugin manager) task 0,wwp0s20f0u6i12: started
ModemManager[6189]: <debug> [1490218304.685764] [mm-plugin-manager.c:519] port_context_next(): [plugin manager] task 0,wwp0s20f0u6i12: checking with plugin 'Sierra'
ModemManager[6189]: <debug> [1490218304.685774] [mm-plugin.c:730] mm_plugin_supports_port(): (Sierra) [wwp0s20f0u6i12] probing deferred until result suggested
ModemManager[6189]: <debug> [1490218304.685855] [mm-plugin-manager.c:1110] device_context_min_wait_time_elapsed(): [plugin manager] task 1: min wait time elapsed
ModemManager[6189]: <debug> [1490218304.685919] [mm-plugin.c:264] apply_pre_probing_filters(): (Option High-Speed) [wlp4s0] filtered by drivers
ModemManager[6189]: <debug> [1490218304.685981] [mm-plugin.c:212] apply_pre_probing_filters(): (Nokia) [wlp4s0] filtered by subsystem
ModemManager[6189]: <debug> [1490218304.685988] [mm-plugin.c:376] apply_pre_probing_filters(): (X22X) [wlp4s0] filtered by vendor/product IDs
ModemManager[6189]: <debug> [1490218304.685993] [mm-plugin.c:212] apply_pre_probing_filters(): (Longcheer) [wlp4s0] filtered by subsystem
ModemManager[6189]: <debug> [1490218304.685999] [mm-plugin.c:212] apply_pre_probing_filters(): (Iridium) [wlp4s0] filtered by subsystem
ModemManager[6189]: <debug> [1490218304.686005] [mm-plugin.c:376] apply_pre_probing_filters(): (Samsung) [wlp4s0] filtered by vendor/product IDs
ModemManager[6189]: <debug> [1490218304.686011] [mm-plugin.c:212] apply_pre_probing_filters(): (Via CBP7) [wlp4s0] filtered by subsystem
ModemManager[6189]: <debug> [1490218304.686017] [mm-plugin.c:212] apply_pre_probing_filters(): (Wavecom) [wlp4s0] filtered by subsystem
ModemManager[6189]: <debug> [1490218304.686022] [mm-plugin.c:212] apply_pre_probing_filters(): (Telit) [wlp4s0] filtered by subsystem
ModemManager[6189]: <debug> [1490218304.686053] [mm-plugin.c:376] apply_pre_probing_filters(): (Altair LTE) [wlp4s0] filtered by vendor/product IDs
ModemManager[6189]: <debug> [1490218304.686102] [mm-plugin.c:212] apply_pre_probing_filters(): (Linktop) [wlp4s0] filtered by subsystem
ModemManager[6189]: <debug> [1490218304.686148] [mm-plugin.c:212] apply_pre_probing_filters(): (MTK) [wlp4s0] filtered by subsystem
ModemManager[6189]: <debug> [1490218304.686218] [mm-plugin.c:376] apply_pre_probing_filters(): (Dell) [wlp4s0] filtered by vendor/product IDs
ModemManager[6189]: <debug> [1490218304.686225] [mm-plugin.c:212] apply_pre_probing_filters(): (Option) [wlp4s0] filtered by subsystem
ModemManager[6189]: <debug> [1490218304.686230] [mm-plugin.c:376] apply_pre_probing_filters(): (AnyDATA) [wlp4s0] filtered by vendor/product IDs
ModemManager[6189]: <debug> [1490218304.686236] [mm-plugin.c:212] apply_pre_probing_filters(): (Thuraya) [wlp4s0] filtered by subsystem
ModemManager[6189]: <debug> [1490218304.686243] [mm-plugin.c:376] apply_pre_probing_filters(): (Novatel LTE) [wlp4s0] filtered by vendor/product IDs
ModemManager[6189]: <debug> [1490218304.686249] [mm-plugin.c:376] apply_pre_probing_filters(): (ZTE) [wlp4s0] filtered by vendor/product IDs
ModemManager[6189]: <debug> [1490218304.686255] [mm-plugin.c:376] apply_pre_probing_filters(): (Novatel) [wlp4s0] filtered by vendor/product IDs
ModemManager[6189]: <debug> [1490218304.686292] [mm-plugin.c:376] apply_pre_probing_filters(): (Cinterion) [wlp4s0] filtered by vendor/product IDs
ModemManager[6189]: <debug> [1490218304.686343] [mm-plugin.c:212] apply_pre_probing_filters(): (Haier) [wlp4s0] filtered by subsystem
ModemManager[6189]: <debug> [1490218304.686393] [mm-plugin.c:212] apply_pre_probing_filters(): (Motorola) [wlp4s0] filtered by subsystem
ModemManager[6189]: <debug> [1490218304.686458] [mm-plugin.c:376] apply_pre_probing_filters(): (SimTech) [wlp4s0] filtered by vendor/product IDs
ModemManager[6189]: <debug> [1490218304.686464] [mm-plugin.c:376] apply_pre_probing_filters(): (Nokia (Icera)) [wlp4s0] filtered by vendor/product IDs
ModemManager[6189]: <debug> [1490218304.686469] [mm-plugin.c:376] apply_pre_probing_filters(): (Huawei) [wlp4s0] filtered by vendor/product IDs
ModemManager[6189]: <debug> [1490218304.686475] [mm-plugin.c:376] apply_pre_probing_filters(): (Pantech) [wlp4s0] filtered by vendor/product IDs
ModemManager[6189]: <debug> [1490218304.686481] [mm-plugin.c:264] apply_pre_probing_filters(): (Sierra (legacy)) [wlp4s0] filtered by drivers
ModemManager[6189]: <debug> [1490218304.686487] [mm-plugin.c:264] apply_pre_probing_filters(): (Sierra) [wlp4s0] filtered by drivers
ModemManager[6189]: <debug> [1490218304.686494] [mm-plugin.c:430] apply_pre_probing_filters(): (Ericsson MBM) [wlp4s0] filtered by udev tags
ModemManager[6189]: <debug> [1490218304.686504] [mm-plugin-manager.c:599] port_context_run(): [plugin manager] task 1,wlp4s0: found '1' plugins to try
ModemManager[6189]: <debug> [1490218304.686552] [mm-plugin-manager.c:622] port_context_run(): [plugin manager] task 1,wlp4s0: will try with plugin 'Generic'
ModemManager[6189]: <debug> [1490218304.686616] [mm-plugin-manager.c:635] port_context_run(): [plugin manager) task 1,wlp4s0: started
ModemManager[6189]: <debug> [1490218304.686663] [mm-plugin-manager.c:519] port_context_next(): [plugin manager] task 1,wlp4s0: checking with plugin 'Generic'
ModemManager[6189]: <debug> [1490218304.686714] [mm-plugin.c:730] mm_plugin_supports_port(): (Generic) [wlp4s0] probing deferred until result suggested
ModemManager[6189]: <debug> [1490218304.686723] [mm-plugin-manager.c:1110] device_context_min_wait_time_elapsed(): [plugin manager] task 2: min wait time elapsed
ModemManager[6189]: <debug> [1490218304.686731] [mm-plugin.c:264] apply_pre_probing_filters(): (Option High-Speed) [enp0s31f6] filtered by drivers
ModemManager[6189]: <debug> [1490218304.686737] [mm-plugin.c:212] apply_pre_probing_filters(): (Nokia) [enp0s31f6] filtered by subsystem
ModemManager[6189]: <debug> [1490218304.686743] [mm-plugin.c:376] apply_pre_probing_filters(): (X22X) [enp0s31f6] filtered by vendor/product IDs
ModemManager[6189]: <debug> [1490218304.686750] [mm-plugin.c:212] apply_pre_probing_filters(): (Longcheer) [enp0s31f6] filtered by subsystem
ModemManager[6189]: <debug> [1490218304.686785] [mm-plugin.c:212] apply_pre_probing_filters(): (Iridium) [enp0s31f6] filtered by subsystem
ModemManager[6189]: <debug> [1490218304.686841] [mm-plugin.c:376] apply_pre_probing_filters(): (Samsung) [enp0s31f6] filtered by vendor/product IDs
ModemManager[6189]: <debug> [1490218304.686894] [mm-plugin.c:212] apply_pre_probing_filters(): (Via CBP7) [enp0s31f6] filtered by subsystem
ModemManager[6189]: <debug> [1490218304.686956] [mm-plugin.c:212] apply_pre_probing_filters(): (Wavecom) [enp0s31f6] filtered by subsystem
ModemManager[6189]: <debug> [1490218304.686962] [mm-plugin.c:212] apply_pre_probing_filters(): (Telit) [enp0s31f6] filtered by subsystem
ModemManager[6189]: <debug> [1490218304.686968] [mm-plugin.c:376] apply_pre_probing_filters(): (Altair LTE) [enp0s31f6] filtered by vendor/product IDs
ModemManager[6189]: <debug> [1490218304.686974] [mm-plugin.c:212] apply_pre_probing_filters(): (Linktop) [enp0s31f6] filtered by subsystem
ModemManager[6189]: <debug> [1490218304.686980] [mm-plugin.c:212] apply_pre_probing_filters(): (MTK) [enp0s31f6] filtered by subsystem
ModemManager[6189]: <debug> [1490218304.686986] [mm-plugin.c:376] apply_pre_probing_filters(): (Dell) [enp0s31f6] filtered by vendor/product IDs
ModemManager[6189]: <debug> [1490218304.686992] [mm-plugin.c:212] apply_pre_probing_filters(): (Option) [enp0s31f6] filtered by subsystem
ModemManager[6189]: <debug> [1490218304.686997] [mm-plugin.c:376] apply_pre_probing_filters(): (AnyDATA) [enp0s31f6] filtered by vendor/product IDs
ModemManager[6189]: <debug> [1490218304.687057] [mm-plugin.c:212] apply_pre_probing_filters(): (Thuraya) [enp0s31f6] filtered by subsystem
ModemManager[6189]: <debug> [1490218304.687107] [mm-plugin.c:376] apply_pre_probing_filters(): (Novatel LTE) [enp0s31f6] filtered by vendor/product IDs
ModemManager[6189]: <debug> [1490218304.687158] [mm-plugin.c:376] apply_pre_probing_filters(): (ZTE) [enp0s31f6] filtered by vendor/product IDs
ModemManager[6189]: <debug> [1490218304.687199] [mm-plugin.c:376] apply_pre_probing_filters(): (Novatel) [enp0s31f6] filtered by vendor/product IDs
ModemManager[6189]: <debug> [1490218304.687205] [mm-plugin.c:376] apply_pre_probing_filters(): (Cinterion) [enp0s31f6] filtered by vendor/product IDs
ModemManager[6189]: <debug> [1490218304.687211] [mm-plugin.c:212] apply_pre_probing_filters(): (Haier) [enp0s31f6] filtered by subsystem
ModemManager[6189]: <debug> [1490218304.687217] [mm-plugin.c:212] apply_pre_probing_filters(): (Motorola) [enp0s31f6] filtered by subsystem
ModemManager[6189]: <debug> [1490218304.687223] [mm-plugin.c:376] apply_pre_probing_filters(): (SimTech) [enp0s31f6] filtered by vendor/product IDs
ModemManager[6189]: <debug> [1490218304.687229] [mm-plugin.c:376] apply_pre_probing_filters(): (Nokia (Icera)) [enp0s31f6] filtered by vendor/product IDs
ModemManager[6189]: <debug> [1490218304.687235] [mm-plugin.c:376] apply_pre_probing_filters(): (Huawei) [enp0s31f6] filtered by vendor/product IDs
ModemManager[6189]: <debug> [1490218304.687304] [mm-plugin.c:376] apply_pre_probing_filters(): (Pantech) [enp0s31f6] filtered by vendor/product IDs
ModemManager[6189]: <debug> [1490218304.687356] [mm-plugin.c:264] apply_pre_probing_filters(): (Sierra (legacy)) [enp0s31f6] filtered by drivers
ModemManager[6189]: <debug> [1490218304.687410] [mm-plugin.c:264] apply_pre_probing_filters(): (Sierra) [enp0s31f6] filtered by drivers
ModemManager[6189]: <debug> [1490218304.687444] [mm-plugin.c:430] apply_pre_probing_filters(): (Ericsson MBM) [enp0s31f6] filtered by udev tags
ModemManager[6189]: <debug> [1490218304.687451] [mm-plugin-manager.c:599] port_context_run(): [plugin manager] task 2,enp0s31f6: found '1' plugins to try
ModemManager[6189]: <debug> [1490218304.687457] [mm-plugin-manager.c:622] port_context_run(): [plugin manager] task 2,enp0s31f6: will try with plugin 'Generic'
ModemManager[6189]: <debug> [1490218304.687465] [mm-plugin-manager.c:635] port_context_run(): [plugin manager) task 2,enp0s31f6: started
ModemManager[6189]: <debug> [1490218304.687471] [mm-plugin-manager.c:519] port_context_next(): [plugin manager] task 2,enp0s31f6: checking with plugin 'Generic'
ModemManager[6189]: <debug> [1490218304.687480] [mm-plugin.c:730] mm_plugin_supports_port(): (Generic) [enp0s31f6] probing deferred until result suggested
ModemManager[6189]: <debug> [1490218304.687541] [mm-plugin-manager.c:453] port_context_defer_until_suggested(): [plugin manager] task 0,wwp0s20f0u6i12: deferring support check until result suggested
ModemManager[6189]: <debug> [1490218304.687644] [mm-plugin-manager.c:453] port_context_defer_until_suggested(): [plugin manager] task 1,wlp4s0: deferring support check until result suggested
ModemManager[6189]: <debug> [1490218304.687684] [mm-plugin-manager.c:453] port_context_defer_until_suggested(): [plugin manager] task 2,enp0s31f6: deferring support check until result suggested
ModemManager[6189]: <debug> [1490218304.687696] [mm-port-probe.c:551] wdm_probe_mbim(): (usbmisc/cdc-wdm0) probing MBIM...
ModemManager[6189]: opening device...
ModemManager[6189]: cannot connect to proxy: Could not connect: Connection refused
ModemManager[6189]: spawning new mbim-proxy (try 1)...
ModemManager[6189]: [/dev/cdc-wdm0] Read max control message size from descriptors file: 4096
ModemManager[6189]: [/dev/cdc-wdm0] Sent message...
<<<<<< RAW:
<<<<<<   length = 88
<<<<<<   data   = 03:00:00:00:58:00:00:00:01:00:00:00:01:00:00:00:00:00:00:00:83:8C:F7:FB:8D:0D:4D:7F:87:1E:D7:1D:BE:FB:B3:9B:01:00:00:00:01:00:00:00:28:00:00:00:0C:00:00:00:1A:00:00:00:1E:00:00:00:2F:00:64:00:65:00:76:00:2F:00:63:00:64:00:63:00:2D:00:77:00:64:00:6D:00:30:00:00:00
ModemManager[6189]: [/dev/cdc-wdm0] Sent message (translated)...
<<<<<< Header:
<<<<<<   length      = 88
<<<<<<   type        = command (0x00000003)
<<<<<<   transaction = 1
<<<<<< Fragment header:
<<<<<<   total   = 1
<<<<<<   current = 0
<<<<<< Contents:
<<<<<<   service = 'proxy-control' (838cf7fb-8d0d-4d7f-871e-d71dbefbb39b)
<<<<<<   cid     = 'configuration' (0x00000001)
<<<<<<   type    = 'set' (0x00000001)
ModemManager[6189]: [/dev/cdc-wdm0] Received message...
>>>>>> RAW:
>>>>>>   length = 48
>>>>>>   data   = 03:00:00:80:30:00:00:00:01:00:00:00:01:00:00:00:00:00:00:00:83:8C:F7:FB:8D:0D:4D:7F:87:1E:D7:1D:BE:FB:B3:9B:01:00:00:00:00:00:00:00:00:00:00:00
ModemManager[6189]: [/dev/cdc-wdm0] Received message (translated)...
>>>>>> Header:
>>>>>>   length      = 48
>>>>>>   type        = command-done (0x80000003)
>>>>>>   transaction = 1
>>>>>> Fragment header:
>>>>>>   total   = 1
>>>>>>   current = 0
>>>>>> Contents:
>>>>>>   status error = 'None' (0x00000000)
<<<<<< RAW:
<<<<<<   length = 16
<<<<<<   data   = 01:00:00:00:10:00:00:00:02:00:00:00:00:10:00:00
<<<<<< Header:
<<<<<<   length      = 16
<<<<<<   type        = open (0x00000001)
<<<<<<   transaction = 2
<<<<<< Contents:
<<<<<<   max_control_transfer = 4096
>>>>>> RAW:
>>>>>>   length = 16
>>>>>>   data   = 01:00:00:80:10:00:00:00:02:00:00:00:00:00:00:00
ModemManager[6189]: <debug> [1490218304.794881] [mm-port-probe.c:304] mm_port_probe_set_result_mbim(): (usbmisc/cdc-wdm0) port is MBIM-capable
<<<<<< RAW:
<<<<<<   length = 12
<<<<<<   data   = 02:00:00:00:0C:00:00:00:03:00:00:00
<<<<<< Header:
<<<<<<   length      = 12
<<<<<<   type        = close (0x00000002)
<<<<<<   transaction = 3
>>>>>> RAW:
>>>>>>   length = 16
>>>>>>   data   = 02:00:00:80:10:00:00:00:03:00:00:00:00:00:00:00
ModemManager[6189]: <debug> [1490218304.795190] [mm-plugin-manager.c:283] port_context_supported(): [plugin manager] task 0,cdc-wdm0: found best plugin for port (Sierra)
ModemManager[6189]: <debug> [1490218304.795218] [mm-plugin-manager.c:265] port_context_complete(): [plugin manager] task 0,cdc-wdm0: finished in '1.612882' seconds
ModemManager[6189]: <debug> [1490218304.795243] [mm-plugin-manager.c:913] device_context_set_best_plugin(): [plugin manager] task 0,cdc-wdm0: found best plugin: Sierra
ModemManager[6189]: <debug> [1490218304.795250] [mm-plugin-manager.c:326] port_context_set_suggestion(): [plugin manager] task 0,wwp0s20f0u6i12: deferred task completed, got suggested plugin (Sierra)
ModemManager[6189]: <debug> [1490218304.795260] [mm-plugin-manager.c:1005] device_context_continue(): [plugin Manager] task 0: still 1 running probes (1 active): wwp0s20f0u6i12
ModemManager[6189]: <debug> [1490218304.795281] [mm-plugin-manager.c:519] port_context_next(): [plugin manager] task 0,wwp0s20f0u6i12: checking with plugin 'Sierra'
ModemManager[6189]: <debug> [1490218304.795417] [mm-plugin.c:730] mm_plugin_supports_port(): (Sierra) [wwp0s20f0u6i12] probing deferred until result suggested
ModemManager[6189]: <debug> [1490218304.795474] [mm-plugin-manager.c:434] port_context_defer_until_suggested(): [plugin manager] task 0,wwp0s20f0u6i12: completed, got suggested plugin (Sierra)
ModemManager[6189]: <debug> [1490218304.795482] [mm-plugin-manager.c:265] port_context_complete(): [plugin manager] task 0,wwp0s20f0u6i12: finished in '1.613733' seconds
ModemManager[6189]: <debug> [1490218304.795490] [mm-plugin-manager.c:966] device_context_set_best_plugin(): [plugin manager] task 0,wwp0s20f0u6i12: best plugin matches device reported one: Sierra
ModemManager[6189]: <debug> [1490218304.795501] [mm-plugin-manager.c:979] device_context_continue(): [plugin manager] task 0: no more ports to probe
ModemManager[6189]: <debug> [1490218304.795542] [mm-plugin-manager.c:813] device_context_complete(): [plugin manager] task 0: finished in '1.613850' seconds
ModemManager[6189]: <info>  [1490218304.795654] [mm-device.c:525] mm_device_create_modem(): Creating modem with plugin 'Sierra' and '2' ports
ModemManager[6189]: <debug> [1490218304.795698] [sierra/mm-plugin-sierra.c:66] create_modem(): MBIM-powered Sierra modem found...
ModemManager[6189]: <debug> [1490218304.796317] [mm-base-modem.c:280] mm_base_modem_grab_port(): (cdc-wdm0) type 'mbim' claimed by /sys/devices/pci0000:00/0000:00:14.0/usb1/1-6
ModemManager[6189]: <debug> [1490218304.796339] [mm-base-modem.c:280] mm_base_modem_grab_port(): (wwp0s20f0u6i12) type 'net' claimed by /sys/devices/pci0000:00/0000:00:14.0/usb1/1-6
ModemManager[6189]: <debug> [1490218304.796353] [mm-base-modem.c:864] log_port(): (/sys/devices/pci0000:00/0000:00:14.0/usb1/1-6) net/wwp0s20f0u6i12 data (primary)
ModemManager[6189]: <debug> [1490218304.796360] [mm-base-modem.c:864] log_port(): (/sys/devices/pci0000:00/0000:00:14.0/usb1/1-6) usb/cdc-wdm0 mbim (primary)
ModemManager[6189]: <info>  [1490218304.796512] [mm-base-manager.c:175] device_support_check_ready(): Modem for device at '/sys/devices/pci0000:00/0000:00:14.0/usb1/1-6' successfully created
<<<<<< RAW:
<<<<<<   length = 88
<<<<<< Header:
<<<<<<   length      = 88
<<<<<<   total   = 1
<<<<<<   current = 0
<<<<<< Contents:
ModemManager[6189]: <debug> [1490218305.683706] [mm-plugin-manager.c:1058] device_context_min_probing_time_elapsed(): [plugin manager] task 1: min probing time elapsed
ModemManager[6189]: <debug> [1490218305.683745] [mm-plugin-manager.c:1005] device_context_continue(): [plugin Manager] task 1: still 1 running probes (0 active): wlp4s0
ModemManager[6189]: <debug> [1490218305.683752] [mm-plugin-manager.c:1009] device_context_continue(): [plugin manager] task 1: no active tasks to probe
ModemManager[6189]: <debug> [1490218305.683775] [mm-plugin-manager.c:337] port_context_set_suggestion(): [plugin manager] task 1,wlp4s0: deferred task completed, no suggested plugin
ModemManager[6189]: <debug> [1490218305.683785] [mm-plugin-manager.c:265] port_context_complete(): [plugin manager] task 1,wlp4s0: finished in '2.501858' seconds
ModemManager[6189]: <debug> [1490218305.683829] [mm-plugin-manager.c:892] device_context_set_best_plugin(): [plugin manager] task 1,wlp4s0: not supported by any plugin
ModemManager[6189]: <debug> [1490218305.683846] [mm-device.c:373] mm_device_ignore_port(): Fully ignoring port 'net/wlp4s0' from now on
ModemManager[6189]: <debug> [1490218305.683857] [mm-plugin-manager.c:979] device_context_continue(): [plugin manager] task 1: no more ports to probe
ModemManager[6189]: <debug> [1490218305.683867] [mm-plugin-manager.c:813] device_context_complete(): [plugin manager] task 1: finished in '2.501985' seconds
ModemManager[6189]: <info>  [1490218305.683883] [mm-base-manager.c:155] device_support_check_ready(): Couldn't check support for device at '/sys/devices/pci0000:00/0000:00:1c.2/0000:04:00.0': not supported by any plugin
ModemManager[6189]: <debug> [1490218305.683908] [mm-plugin-manager.c:1058] device_context_min_probing_time_elapsed(): [plugin manager] task 2: min probing time elapsed
ModemManager[6189]: <debug> [1490218305.683917] [mm-plugin-manager.c:1005] device_context_continue(): [plugin Manager] task 2: still 1 running probes (0 active): enp0s31f6
ModemManager[6189]: <debug> [1490218305.683927] [mm-plugin-manager.c:1009] device_context_continue(): [plugin manager] task 2: no active tasks to probe
ModemManager[6189]: <debug> [1490218305.683935] [mm-plugin-manager.c:337] port_context_set_suggestion(): [plugin manager] task 2,enp0s31f6: deferred task completed, no suggested plugin
ModemManager[6189]: <debug> [1490218305.683944] [mm-plugin-manager.c:265] port_context_complete(): [plugin manager] task 2,enp0s31f6: finished in '2.501851' seconds
ModemManager[6189]: <debug> [1490218305.683954] [mm-plugin-manager.c:892] device_context_set_best_plugin(): [plugin manager] task 2,enp0s31f6: not supported by any plugin
ModemManager[6189]: <debug> [1490218305.683964] [mm-device.c:373] mm_device_ignore_port(): Fully ignoring port 'net/enp0s31f6' from now on
ModemManager[6189]: <debug> [1490218305.683973] [mm-plugin-manager.c:979] device_context_continue(): [plugin manager] task 2: no more ports to probe
ModemManager[6189]: <debug> [1490218305.683982] [mm-plugin-manager.c:813] device_context_complete(): [plugin manager] task 2: finished in '2.501929' seconds
ModemManager[6189]: <info>  [1490218305.683993] [mm-base-manager.c:155] device_support_check_ready(): Couldn't check support for device at '/sys/devices/pci0000:00/0000:00:1f.6': not supported by any plugin
>>>>>> RAW:
>>>>>>   length = 48
>>>>>> Header:
>>>>>>   length      = 48
>>>>>>   transaction = 1
>>>>>> Fragment header:
>>>>>>   total   = 1
>>>>>>   current = 0
>>>>>> Contents:
<<<<<< RAW:
<<<<<<   length = 16
<<<<<< Header:
<<<<<<   length      = 16
<<<<<< Contents:
>>>>>> RAW:
>>>>>>   length = 16
ModemManager[6189]: <debug> [1490218309.797132] [mm-broadband-modem-mbim.c:1608] parent_initialization_started_ready(): Couldn't start parent initialization: Couldn't open ports during modem initialization: Couldn't get primary port
ModemManager[6189]: <debug> [1490218309.797474] [mm-broadband-modem-mbim.c:218] modem_load_current_capabilities(): loading current capabilities...
<<<<<< RAW:
<<<<<<   length = 48
<<<<<<   data   = 03:00:00:00:30:00:00:00:03:00:00:00:01:00:00:00:00:00:00:00:A2:89:CC:33:BC:BB:8B:4F:B6:B0:13:3E:C2:AA:E6:DF:01:00:00:00:00:00:00:00:00:00:00:00
<<<<<< Header:
<<<<<<   length      = 48
<<<<<<   total   = 1
<<<<<<   current = 0
<<<<<< Contents:
<<<<<<   service = 'basic-connect' (a289cc33-bcbb-8b4f-b6b0-133ec2aae6df)
<<<<<<   cid     = 'device-caps' (0x00000001)
<<<<<<   type    = 'query' (0x00000000)
ModemManager[6189]: <warn>  [1490218319.807627] [mm-broadband-modem.c:9541] iface_modem_initialize_ready(): Modem couldn't be initialized: couldn't load current capabilities: Transaction timed out
ModemManager[6189]: <debug> [1490218319.807747] [mm-broadband-modem.c:9635] iface_modem_firmware_initialize_ready(): Couldn't initialize interface: 'Firmware interface not available'
ModemManager[6189]: <debug> [1490218319.807801] [mm-base-modem.c:833] initialize_ready(): modem properly initialized
ModemManager[6189]: <debug> [1490218319.808027] [mm-device.c:452] export_modem(): Exported modem '/sys/devices/pci0000:00/0000:00:14.0/usb1/1-6' at path '/org/freedesktop/ModemManager1/Modem/0'
ModemManager[6189]: <debug> [1490218319.808040] [mm-device.c:462] export_modem(): (/org/freedesktop/ModemManager1/Modem/0): 'Sierra' modem, VID 0x1199 PID 0x9079 (usb)
The ModemManager mailing list here is probably a better place to ask:
https://lists.freedesktop.org/mailman/listinfo/modemmanager-devel
Anyway, I’d suggest you try to build and install ModemManager from git master and retry. This could be a “FCC auth” issue, and there are some fixes related to that that haven’t been released in any 1.6.x yet.
