MC7304 disconnects after 24h
MC73, MC74, EM74, MC809x, MC9090
Postby peterdewitte » Tue Feb 07, 2017 11:34 am
My MC7304 modem disconnects after more or less 24h. It is not the usual DHCP issue, because the link disconnects within a lease time of dhclient. If you set up a connection again, the problems are solved again for more or less 24h.
In pastebin I attached the logs of libqmi and ModemManager. It contains the RAW QMI messages as well the translated versions. I try to figure out why the modem after 24h disconnects
This is a link to the log: http://pastebin.com/iTDGqxnj
Till line 50: Everything goes well, ModemManager polls the signal strength. This goes on for 24h. I left one in as an example
From line 50: From this message onwards, the connection gets killed.
This behavior happens on two different mobile operators.
These are the versions I am using:
Modem: MC7304
Kernel: 3.16
ModemManager: 1.4.18
Libqmi: 1.17.900
What is going wrong in the QMI messages an how can I fix it?
peterdewitte
Has thanked: 0 time
Have thanks: 0 time
Re: MC7304 disconnects after 24h
Postby cloud huang » Fri Apr 14, 2017 2:09 am
check AT+CPIN? when it disconnected
cloud huang
Has thanked: 4 times
Have thanks: 0 time
Postby okqqkimo1 » Wed Apr 19, 2017 6:48 pm
The issue seem cause by carrier.
I don't know which carrier you are used.
but there are many carrier will let UE disconnect and the UE need re-connect.
It is make sure the resource is alive.
okqqkimo1
Has thanked: 5 times
Have thanks: 2 times
Return to MC Series + EM74
Who is online
Users browsing this forum: No registered users and 3 guests
