Airlink FX-100 support Sim Toolkit ?
May I know if Airlink FX100 support Sim Toolkit ?
When I insert the SIM into FX100 and use AT +STGI=0 , the command returned nothing, but when I put the same SIM into other modem, it will give me a list of menu when I use the same command.
Thank you
It should support SIM tool kit…
Check with your command sequence once…
Did you set AT+STSF???
-Alex
