As described above, I urgently need the driver for the module above.
Can anyone help me?
If it’s urgent, then your Distributor is probably the best place to go …
There are no Win7 embedded drivers for the GL8.
Win7 embedded is not supported with this product
If this one doesn’t support Win7embedded, which one would fit instead?
From the GL6200 page:
source.sierrawireless.com/devic … es/gl8200/
you can see various other GLxxxx options
The GL6100 is the same as the GL6200 - but with RS232 instead of USB. You could use that with a USB-to-RS232 converter …
(if it’s still available)
