I resolved this problem
- I made a change in the model file ā.appā (e.g. AVSampleDemo.app).
- I Selected the file.dwl (e.g. AVSampleDemo.dwl) in this folder: ā[Target]_ARM_EABI_GCCfolder_Debugā and i copy & paste it in the Model folder.
- I created a zip file with .app and .dwl file.
- Finally, i uploaded zip file in AirVantage.
Here is my xml code in āAVSampleDemo.appā :
<?xml version="1.0" encoding="ASCII"?>
<appmodel:application xmlns:appmodel="http://www.sierrawireless.com/airvantage/application/1.0" type="Telnet.AVSampleDemo Sample" name="AVSampleDemo Sample" revision="1.0.0.20170817122342">
<capabilities>
<communication>
<protocol comm-id="IMEI" type="AWTDA2" >
<parameter name="sms-binary" value="false" />
</protocol>
</communication>
<data>
<encoding type="AWTDA2">
<asset id="MyAsset" default-label="AVSampleDemo">
<variable path="message" default-label="Test message">
<description>Test message</description>
</variable>
<setting path="setting" default-label="Test setting" type="int">
<description></description>
</setting>
<node path="0" default-label="events">
<event path="100" default-label="MESSAGE_SET">
</event>
</node>
<command path="setMessage" default-label="Set message">
<parameter id="message" default-label="Message"/>
</command>
</asset>
</encoding>
</data>
</capabilities>
<application-manager use="SOFT_IDS"/>
<binaries>
<binary file="AVSampleDemo.dwl" type="FULL"/>
</binaries>
</appmodel:application>
