[Sample SPI]ACT&INACT accelerometer's events ADXL345+FXT009
Share your code with other community members. Please do not ask for code here; use the appropriate product forum instead.
Postby mikinacucchi » Mon Aug 12, 2013 12:58 pm
Hardware
  • FXT009 + adapter for FXTE(50pin Expansion Card) to development
  • AnalogDevice ADXL345(datasheet) mounted on GY-29 board(pinout)
pin connection:
FXTE(50pin) <-> ADXL345
11 GSM 2V8 <-> Vcc
15 SPI1-CS /GPIO31 <-> CS
16 SPI1-CLK <-> SCLK
17 SPI1-I <-> SDO
18 SPI1-IO <-> SDI
29 GPIO19 <-> INT1
33 GPIO23 <-> INT2
49 GND <-> GND
picture 1
picture 2
OpenAT
I use adl_bus Library to comunicate with ADXL346(work also with I2C).
The function ADXL345_gpioInt() init three GPIO used and subscribe gpio event handler.
  • GPIO31 as output used as "manual CS"
  • GPIO19 and 23 as input to detect INT1&INT2 HIGH
After SPI bus initialized the ADXL345_setup() function set some registers to detect ACTIVITY and INACTIVITY events by interrupts
Code
  • adxl345_spi.h
    Code: Select all
     * adxl345_spi.h
     *  Created on: Jul 12, 2013
     *      Author: Miki Nacucchi
    #ifndef ADXL345_SPI_H_
    #define ADXL345_SPI_H_
    /* ------- Register names ------- */
    #define ADXL345_DEVID          0x00
    #define ADXL345_RESERVED1      0x01
    #define ADXL345_THRESH_TAP      0x1d
    #define ADXL345_OFSX         0x1e
    #define ADXL345_OFSY         0x1f
    #define ADXL345_OFSZ         0x20
    #define ADXL345_DUR            0x21
    #define ADXL345_LATENT         0x22
    #define ADXL345_WINDOW         0x23
    #define ADXL345_THRESH_ACT      0x24
    #define ADXL345_THRESH_INACT   0x25
    #define ADXL345_TIME_INACT      0x26
    #define ADXL345_ACT_INACT_CTL   0x27
    #define ADXL345_THRESH_FF      0x28
    #define ADXL345_TIME_FF         0x29
    #define ADXL345_TAP_AXES      0x2a
    #define ADXL345_ACT_TAP_STATUS   0x2b
    #define ADXL345_BW_RATE         0x2c
    #define ADXL345_POWER_CTL      0x2d
    #define ADXL345_INT_ENABLE      0x2e
    #define ADXL345_INT_MAP         0x2f
    #define ADXL345_INT_SOURCE      0x30
    #define ADXL345_DATA_FORMAT      0x31
    #define ADXL345_DATAX0         0x32
    #define ADXL345_DATAX1         0x33
    #define ADXL345_DATAY0         0x34
    #define ADXL345_DATAY1         0x35
    #define ADXL345_DATAZ0         0x36
    #define ADXL345_DATAZ1         0x37
    #define ADXL345_FIFO_CTL      0x38
    #define ADXL345_FIFO_STATUS      0x39
    //ADXL345_DEVID default value
    #define ADXL345_DEVID_VALUE      0xE5
     Interrupt bit position in reg ADXL345_INT_ENABLE
    #define ADXL345_INT_DATA_READY_BIT 0x07
    #define ADXL345_INT_SINGLE_TAP_BIT 0x06
    #define ADXL345_INT_DOUBLE_TAP_BIT 0x05
    #define ADXL345_INT_ACTIVITY_BIT   0x04
    #define ADXL345_INT_INACTIVITY_BIT 0x03
    #define ADXL345_INT_FREE_FALL_BIT  0x02
    #define ADXL345_INT_WATERMARK_BIT  0x01
    #define ADXL345_INT_OVERRUNY_BIT   0x00
     Flag position in reg ADXL345_INT_SOURCE
    #define ADXL345_DATA_READY   0x07
    #define ADXL345_SINGLE_TAP   0x06
    #define ADXL345_DOUBLE_TAP   0x05
    #define ADXL345_ACTIVITY   0x04
    #define ADXL345_INACTIVITY   0x03
    #define ADXL345_FREE_FALL   0x02
    #define ADXL345_WATERMARK   0x01
    #define ADXL345_OVERRUNY   0x00
    #define ADXL345_ADDLENGTH   0x06
     * GPIO def
    #define ADXL345_GPIO_COUNT   3
    #define ADXL345_GPIO_CS      31
    #define ADXL345_GPIO_INT1   19
    #define ADXL345_GPIO_INT2   23
    void ADXL345_setup();
    void ADXL345_writeReg(u8 reg, u8 value);
    void ADXL345_readReg(u8 reg, u8 length, void *buffer);
    #endif /* ADXL345_SPI_H_ */
  • main.c
    Code: Select all
     * main.c
    #include "adl_global.h"
    #include "generated.h"
    #include "adl_bus.h"
    #include "adxl345_spi.h"
    #include "adl_traces.h"
    #define TRACE_LEVEL   5
    adl_ioDefs_t gpioConfig[ADXL345_GPIO_COUNT] =
          ADL_IO_GPIO   |   ADXL345_GPIO_CS      |    ADL_IO_DIR_OUT    |    ADL_IO_LEV_HIGH,   //CS
          ADL_IO_GPIO   |   ADXL345_GPIO_INT1   |    ADL_IO_DIR_IN,                      //ADXL345_INT1
          ADL_IO_GPIO   |   ADXL345_GPIO_INT2   |    ADL_IO_DIR_IN                      //ADXL345_INT2
    s32 ADXL345_gpioHandle;
    void ADXL345_gpioEventHandler( s32 GpioHandle, adl_ioEvent_e Event, u32 Size, void * Param ){
       //TRACE((TRACE_LEVEL,"ADXL345_gpioEventHandler"));
       if(Event != ADL_IO_EVENT_INPUT_CHANGED)
          return;
       bool readIntSource = false;
       unsigned int i=0;
       for(; i<Size ; i++){
          adl_ioDefs_t gpio = ((adl_ioDefs_t *)Param)[i];
          switch (gpio & ADL_IO_NUM_MSK) {
             case ADXL345_GPIO_INT1:
                if((gpio & ADL_IO_LEV_HIGH) > 0){
                   TRACE((TRACE_LEVEL,"ADXL345_GPIO_INT1 | ADL_IO_LEV_HIGH"));
                   readIntSource = true;
                //else
                //   TRACE((TRACE_LEVEL,"ADXL345_GPIO_INT1 | ADL_IO_LEV_LOW"));
                break;
             case ADXL345_GPIO_INT2:
                   TRACE((TRACE_LEVEL,"ADXL345_GPIO_INT2 | ADL_IO_LEV_HIGH"));
                //else
                //   TRACE((TRACE_LEVEL,"ADXL345_GPIO_INT2 | ADL_IO_LEV_LOW"));
                break;
       if(readIntSource){
          char values[1];
          ADXL345_readReg(ADXL345_INT_SOURCE, 1, values);
          //TRACE((TRACE_LEVEL,"ADXL345_INT_SOURCE: %x", values[0]));
          //if(values[0] & (1 << ADXL345_DATA_READY))   TRACE((TRACE_LEVEL,"ADXL345_DATA_READY"));
          if(values[0] & (1 << ADXL345_SINGLE_TAP))   TRACE((TRACE_LEVEL,"ADXL345_SINGLE_TAP ADXL345_INT_SOURCE: %x", values[0]));
          if(values[0] & (1 << ADXL345_DOUBLE_TAP))   TRACE((TRACE_LEVEL,"ADXL345_DOUBLE_TAP ADXL345_INT_SOURCE: %x", values[0]));
          if(values[0] & (1 << ADXL345_ACTIVITY))      TRACE((TRACE_LEVEL,"ADXL345_ACTIVITY ADXL345_INT_SOURCE: %x", values[0]));
          if(values[0] & (1 << ADXL345_INACTIVITY))   TRACE((TRACE_LEVEL,"ADXL345_INACTIVITY ADXL345_INT_SOURCE: %x", values[0]));
          if(values[0] & (1 << ADXL345_FREE_FALL))   TRACE((TRACE_LEVEL,"ADXL345_FREE_FALL ADXL345_INT_SOURCE: %x", values[0]));
          //if(values[0] & (1 << ADXL345_WATERMARK))   TRACE((TRACE_LEVEL,"ADXL345_WATERMARK"));
          //if(values[0] & (1 << ADXL345_OVERRUNY))   TRACE((TRACE_LEVEL,"ADXL345_OVERRUNY"));
    void ADXL345_gpioInt(){
       s32 gpioEventSub = adl_ioEventSubscribe(ADXL345_gpioEventHandler);
       switch (gpioEventSub) {
          case ADL_RET_ERR_PARAM:
             TRACE((TRACE_LEVEL, "adl_ioEventSubscribe ERR ADL_RET_ERR_PARAM"));
             return;
          case ADL_RET_ERR_SERVICE_LOCKED:
             TRACE((TRACE_LEVEL, "adl_ioEventSubscribe ERR ADL_RET_ERR_SERVICE_LOCKED"));
             return;
          default:
             TRACE((TRACE_LEVEL, "adl_ioEventSubscribe OK"));
             break;
       ADXL345_gpioHandle = adl_ioSubscribe (ADXL345_GPIO_COUNT, gpioConfig, ADL_TMR_TYPE_100MS, (u32)0x01, gpioEventSub);
       switch (ADXL345_gpioHandle) {
             TRACE((TRACE_LEVEL, "adl_ioSubscribe ERR ADL_RET_ERR_PARAM"));
             break;
          case ADL_RET_ERR_DONE:
             TRACE((TRACE_LEVEL,"adl_ioSubscribe ERR ADL_RET_ERR_DONE"));
             break;
          case ADL_RET_ERR_NO_MORE_TIMERS:
             TRACE((TRACE_LEVEL,"adl_ioSubscribe ERR ADL_RET_ERR_NO_MORE_TIMERS"));
             break;
          case ADL_RET_ERR_NO_MORE_HANDLES:
             TRACE((TRACE_LEVEL,"adl_ioSubscribe ERR ADL_RET_ERR_NO_MORE_HANDLES"));
             break;
             TRACE((TRACE_LEVEL,"adl_ioSubscribe ERR ADL_RET_ERR_SERVICE_LOCKED"));
             break;
          default:
             TRACE((TRACE_LEVEL,"adl_ioSubscribe OK"));
             break;
    void ADXL345_CS_setLow() {
       gpioConfig[0] &= ~ADL_IO_LEV_HIGH;
       switch (adl_ioWrite(ADXL345_gpioHandle, ADXL345_GPIO_COUNT, gpioConfig)) {
          case OK://If one parameter has an incorrect value.
          //    TRACE((TRACE_LEVEL,"adl_ioWrite  - OK"));
             break;
          case ADL_RET_ERR_PARAM:// if one parameter has an incorrect value.
             TRACE((TRACE_LEVEL,"adl_ioWrite  - ADL_RET_ERR_PARAM"));
             break;
          case ADL_RET_ERR_DONE://refers to the field #adl_ioError_e for more informations.  If the error information is #ADL_IO_GNOERR, the process has been completed with success for this GPIO.
             TRACE((TRACE_LEVEL,"adl_ioWrite  - ADL_RET_ERR_DONE"));
             break;
          case ADL_RET_ERR_UNKNOWN_HDL://if the handle is unknown
             TRACE((TRACE_LEVEL,"adl_ioWrite  - ADL_RET_ERR_UNKNOWN_HDL"));
    void ADXL345_CS_setHigh() {
       gpioConfig[0] += ADL_IO_LEV_HIGH;
             break;
             break;
             break;
    // SPI Subscription data [Customize for ADXL345]
    const adl_busSPISettings_t ADXL345_SPIConfig = {
       2,  //ADXL max Clock = 5MHz => MaxFrequency / ( 1 + ClkSpeed ) = 13000 / (1 + 2) = 4300
       ADL_BUS_SPI_CLK_MODE_3, // Mode 3: rest state 1, data valid on falling edge
       ADL_BUS_SPI_ADDR_CS_NONE,//[not used]
       ADL_BUS_SPI_CS_POL_LOW, // Chip Select active in low state
       ADL_BUS_SPI_MSB_FIRST,
       ADL_IO_GPIO,         //[not used]
       ADL_BUS_SPI_LOAD_UNUSED,// LOAD signal [not used]
       ADL_BUS_SPI_DATA_UNIDIR,//3 wires mode (MISO, MOSI and CLK), two pins are used to handle separately input & output data signals
       ADL_BUS_SPI_MASTER_MODE,// Master mode
       ADL_BUS_SPI_BUSY_UNUSED //BUSY signal [not used]
    // BUS Handles
    s32 ADXL345_SPIHandle;
    void MyFunction ( void ){
       TRACE((TRACE_LEVEL,"MyFunction"));
       ADXL345_gpioInt();
       // Subscribe to the SPI1 BUS
       ADXL345_SPIHandle = adl_busSubscribe ( ADL_BUS_ID_SPI, (u32)1, (void*)&ADXL345_SPIConfig );
       switch (ADXL345_SPIHandle) {
          case ADL_RET_ERR_PARAM://If one parameter has an incorrect value.
              TRACE((TRACE_LEVEL,"adl_busSubscribe  - ADL_RET_ERR_PARAM"));
             break;
          case ADL_RET_ERR_BAD_HDL://If the bus is already open with this chip select or in a configuration uncompatible with this chip select.
             TRACE((TRACE_LEVEL,"adl_busSubscribe  - ADL_RET_ERR_BAD_HDL"));
             break;
          case ADL_RET_ERR_NOT_SUPPORTED://If a GPIO required by the provided bus configuration is currently subscribed by an Open AT<sup>®</sup> application.
             TRACE((TRACE_LEVEL,"adl_busSubscribe  - ADL_RET_ERR_NOT_SUPPORTED"));
             break;
          case ADL_RET_ERR_SERVICE_LOCKED://If the required bus type is not supported by the Wireless CPU on which the application is running.
             TRACE((TRACE_LEVEL,"adl_busSubscribe  - ADL_RET_ERR_SERVICE_LOCKED"));
             break;
          default://OK
             TRACE((TRACE_LEVEL,"adl_busSubscribe  - OK"));
             /**/u32 param = 8;
             switch (adl_busIOCtl ( ADXL345_SPIHandle, ADL_BUS_CMD_SET_ADD_SIZE, &param )) {
                case OK://On success
                 TRACE((TRACE_LEVEL,"adl_busIOCtl ADL_BUS_CMD_SET_ADD_SIZE - OK"));
                break;
                 TRACE((TRACE_LEVEL,"adl_busIOCtl ADL_BUS_CMD_SET_ADD_SIZE - ADL_RET_ERR_PARAM"));
                break;
                case ADL_RET_ERR_UNKNOWN_HDL://If the handle is unknown.
                 TRACE((TRACE_LEVEL,"adl_busIOCtl ADL_BUS_CMD_SET_ADD_SIZE - ADL_RET_ERR_UNKNOWN_HDL"));
                break;
                case ADL_RET_ERR_DONE:// If a error occurs during the operation.
                 TRACE((TRACE_LEVEL,"adl_busIOCtl ADL_BUS_CMD_SET_ADD_SIZE - ADL_RET_ERR_DONE"));
                break;
                case ADL_RET_ERR_BAD_HDL://If the required command is not usable for the current handle.
                 TRACE((TRACE_LEVEL,"adl_busIOCtl ADL_BUS_CMD_SET_ADD_SIZE - ADL_RET_ERR_BAD_HDL"));
                break;
                case ADL_RET_ERR_SERVICE_LOCKED://If the function was called from a low level interrupt handler (the function is forbidden in this context).
                 TRACE((TRACE_LEVEL,"adl_busIOCtl ADL_BUS_CMD_SET_ADD_SIZE - ADL_RET_ERR_SERVICE_LOCKED"));
                break;
                case ADL_RET_ERR_NOT_SUPPORTED://If the capabilities inform that no Asynchronous mode is possible
                 TRACE((TRACE_LEVEL,"adl_busIOCtl ADL_BUS_CMD_SET_ADD_SIZE - ADL_RET_ERR_NOT_SUPPORTED"));
                break;
             switch (adl_busIOCtl ( ADXL345_SPIHandle, ADL_BUS_CMD_SET_DATA_SIZE , &param)) {
                 TRACE((TRACE_LEVEL,"adl_busIOCtl ADL_BUS_CMD_SET_DATA_SIZE - OK"));
                break;
                 TRACE((TRACE_LEVEL,"adl_busIOCtl ADL_BUS_CMD_SET_DATA_SIZE - ADL_RET_ERR_PARAM"));
                break;
                 TRACE((TRACE_LEVEL,"adl_busIOCtl ADL_BUS_CMD_SET_DATA_SIZE - ADL_RET_ERR_UNKNOWN_HDL"));
                break;
                 TRACE((TRACE_LEVEL,"adl_busIOCtl ADL_BUS_CMD_SET_DATA_SIZE - ADL_RET_ERR_DONE"));
                break;
                 TRACE((TRACE_LEVEL,"adl_busIOCtl ADL_BUS_CMD_SET_DATA_SIZE - ADL_RET_ERR_BAD_HDL"));
                break;
                 TRACE((TRACE_LEVEL,"adl_busIOCtl ADL_BUS_CMD_SET_DATA_SIZE - ADL_RET_ERR_SERVICE_LOCKED"));
                break;
                 TRACE((TRACE_LEVEL,"adl_busIOCtl ADL_BUS_CMD_SET_DATA_SIZE - ADL_RET_ERR_NOT_SUPPORTED"));
                break;
             ADXL345_setup();
             break;
    // Access configuration structure
    adl_busAccess_t AccessConfig ={
          0, 0 // No Opcode, No Address
    void ADXL345_writeReg(u8 reg, u8 value){
       ADXL345_CS_setLow();
       AccessConfig.Address = (u32)(reg << 24);//32bit required!
       //AccessConfig.Address = (u32)reg;
       u8 pDataToWrite[1] = { value };
       switch (adl_busWrite ( ADXL345_SPIHandle, &AccessConfig, 1, pDataToWrite )) {
              //TRACE((TRACE_LEVEL,"adl_busWrite  - OK"));
             break;
          case ERROR://If the bus is already open with this chip select or in a configuration uncompatible with this chip select.
             TRACE((TRACE_LEVEL,"adl_busWrite  - ERROR"));
             break;
          case ADL_RET_ERR_PARAM://If a GPIO required by the provided bus configuration is currently subscribed by an Open AT<sup>®</sup> application.
             TRACE((TRACE_LEVEL,"adl_busWrite  - ADL_RET_ERR_PARAM"));
             break;
          case ADL_RET_ERR_UNKNOWN_HDL://If a GPIO required by the provided bus configuration is currently subscribed by an Open AT<sup>®</sup> application.
             TRACE((TRACE_LEVEL,"adl_busWrite  - ADL_RET_ERR_UNKNOWN_HDL"));
             break;
             TRACE((TRACE_LEVEL,"adl_busWrite  - ADL_RET_ERR_SERVICE_LOCKED"));
       AccessConfig.Address = 0;
       ADXL345_CS_setHigh();
    void ADXL345_readReg(u8 reg, u8 length, void *buffer){
       memset(buffer, length, 0x00);//flush buffer
       reg |= 0x80;//read mode
        switch (adl_busRead ( ADXL345_SPIHandle, &AccessConfig, length, buffer )) {
             // TRACE((TRACE_LEVEL,"adl_busRead  - OK"));
             break;
             TRACE((TRACE_LEVEL,"adl_busRead  - ERROR"));
             break;
             TRACE((TRACE_LEVEL,"adl_busRead  - ADL_RET_ERR_PARAM"));
             break;
             TRACE((TRACE_LEVEL,"adl_busRead  - ADL_RET_ERR_UNKNOWN_HDL"));
             break;
             TRACE((TRACE_LEVEL,"adl_busRead  - ADL_RET_ERR_SERVICE_LOCKED"));
             break;
    void ADXL345_setup(){
       TRACE((TRACE_LEVEL,"ADXL345_setup"));
       u8 values[1];
       ADXL345_readReg(ADXL345_DEVID, 1, values);
       if(values[0] != ADXL345_DEVID_VALUE)TRACE((TRACE_LEVEL,"ADXL345_DEVID: %x  /!\\ FAIL /!\\", values[0]));//maybe any hardware problems
       else TRACE((TRACE_LEVEL,"ADXL345_DEVID: %x", values[0]));//must be 0xE5 !
       //Put the ADXL345 into +/- 4G range by writing the value 0x01 to the DATA_FORMAT register.
       ADXL345_writeReg(ADXL345_DATA_FORMAT,   0x01);
       //Put the ADXL345 into Measurement Mode AutoSleep enabled
       ADXL345_writeReg(ADXL345_POWER_CTL,      0x18);
       /*      ACTIVITY & INCATIVITY   */
       //Activity Threshold
       ADXL345_writeReg(ADXL345_THRESH_ACT,   0x4B);
       //Inactivity Threshold
       ADXL345_writeReg(ADXL345_THRESH_INACT,   0x25);
       //Inactivity Timeout
       ADXL345_writeReg(ADXL345_TIME_INACT,   0x0A);
       //Enable all axis
       ADXL345_writeReg(ADXL345_ACT_INACT_CTL,   0xFF);
       /*      INTERRUPT   */
       //MAP INT1 ACTIVITY INT2 INACTIVITY(& OTHERS ENABLED)
       ADXL345_writeReg(ADXL345_INT_MAP,   ~(1 << ADXL345_INT_ACTIVITY_BIT));
       //Enable Act e Inact
       ADXL345_writeReg(ADXL345_INT_ENABLE, (1 << ADXL345_INT_ACTIVITY_BIT) | (1 << ADXL345_INT_INACTIVITY_BIT));
       ADXL345_readReg(ADXL345_INT_SOURCE, 1, values);   //CLEAR INT_SOURCE
       if(values[0] & (1 << ADXL345_SINGLE_TAP))   TRACE((TRACE_LEVEL,"ADXL345_SINGLE_TAP"));
       if(values[0] & (1 << ADXL345_DOUBLE_TAP))   TRACE((TRACE_LEVEL,"ADXL345_DOUBLE_TAP"));
       if(values[0] & (1 << ADXL345_ACTIVITY))      TRACE((TRACE_LEVEL,"ADXL345_ACTIVITY"));
       if(values[0] & (1 << ADXL345_INACTIVITY))   TRACE((TRACE_LEVEL,"ADXL345_INACTIVITY"));
       if(values[0] & (1 << ADXL345_FREE_FALL))   TRACE((TRACE_LEVEL,"ADXL345_FREE_FALL"));
       if(values[0] & (1 << ADXL345_OVERRUNY))      TRACE((TRACE_LEVEL,"ADXL345_OVERRUNY"));/**/
    void main_task(void) {
       TRACE((TRACE_LEVEL,"main_task"));
       MyFunction();
I hope that it's all understandable and helpful.
AirLink Fastrack Xtend EDGE FXT009 - AirPrime SL6087
For this post the author mikinacucchi
has been thanked by :
ToF (Mon Aug 19, 2013 6:34 am)
mikinacucchi
Has thanked: 1 time
Have thanks: 1 time
Return to Sample code
Who is online
