Hello every one,
I would like to access to my FTP server installed on my PC via the Q2698 module. But I don’t know how to do this.
First, I have to have an internet connection on my PC via the module. So, i tried with AT commands (at!scact=1,1), sometimes it works sometimes not. This depends if the CID is created or not and mostly the CID=1 is not created even if my APN parameters were correct.
Another try was with the gateway sample provided in developer studio, but it seems there is a firmware issues (69259 in release notes for firmware 7.52.0.A1).
So, i downloaded the AirCard Watcher sofware to solve this problem.
Now, I have an internet access on my PC via the module using this software.
But, now I would like to access to files in this PC via FTP protocol. So I created a FTP server, configured the firewalls and use some OpenAT functions in module to forward packets. I used the wip_netInit() and wip_netInitOpts() functions to put default values and WIP_NET_IP_FORWARD to TRUE.
Then, I used the wip_ipFwdEntryAdd() function to forward the TCP packets for FTP with the internal (private) IP address, external (public) IP address, the port 21 and IPPROTO_TCP as parameters of this function.
So, I don’t kown why I can’t access to my files in FTP. The FTP server has been tested through a local server and is working well.
Any ideas ?
Module : Q2698
Developer Studio : 3.0.0.2014032101015
Open AT Application Framework package : 2.52.0.A1
Open AT OS package : 6.52.0.A1
Internet Library package : 5.56.0.A1
Firmware package : 7.52.0.A1
