Wipsoft or edsoft
Hello everybody,
We want to create an internet connexion using gprs wavecom modem.
modem has open at enabled
model do not have edsoft nor wipsoft
where may i find them :unamused: , how to install them into the modem ? :question:
thanks in advance :neutral_face:
It must be at least 6 years since edsoft was replaced by WIP :question: :exclamation:
Hi, thaks :neutral_face:
I have an old modem for testing purposes.
Is it possible to install wipsoft ? where can i find it ?
could you please give som help on that :question:
That is going to be an adventure in computer archaeology :exclamation:
Unless you are particularly good at, and find particular pleasure in, seeking-out old & obsolete components, software, documentation and tools - I would strongly suggest that you would do far better with a modern modem for which tools, documentation, software, and support are readily available…
Well it is not possible to buy new modems in the test phase.
Thanks anyway, i will continue looking for this issue and let you know if i find a solution for it :unamused:
Hi Sam,
Please list the exact model number and firmware running, but as you mentioned “edsoft”… I believe it is very old…
If you obtained it from a distributor previously, please try to contact them.
Otherwise, I believe a recent module make more sense for development and even for testing and proof-of-concept purpose as latest software will have better performance and features available.
Depends on your location and carrier available, below maybe a good start:
http://developer.sierrawireless.com/Ecosystem/Partners.aspx#&&filter=PartnerCategories-eq-(D4CBEA24-53E4-46A5-89B8-6C7AF3F4A5F1)
Good luck!
L
The amount of time you could waste in trying to track this stuff down could mean that you won’t have time to do anything else :exclamation:
If this is a commercial project, the cost of that time will certainly exceed the cost of a new modem :exclamation:
If it’s a really old modem that don’t have any upgrade path to firmware that wipsoft can run on, you’re SOL.
eDSoft can’t be distributed through any official channels any more.
HI all :slight_smile:
here are the information : wavecom M1306B
AT+CGMR gives
AT+641b09gg.Q2406B 1339080 041604 16:04
and AT+WOPEN=2 gives
+WOPEN: 2, “AT v2.10”, “AT v2.10”
IIRC, the M1306B uses a Q2406B module, and was supported by Open-AT up to about v3.3 - which included the first versions of WIP.
You will need the old tools for this - it doesn’t work with Developer Studio.
so i have to look for at v 3.3 ?
i tried AT+WIPCFG=1 it gives an error
please do you know where can i get the wipsoft.dwl ?
thanks
Attached find some old Versions of WIPsoft. Use at your own risk! :wink:
best regards,
Gregor Bader
Good to know the modem is M1306B, although it is still old products…
v3 in the archive maybe a good start.
[url]http://archive.sierrawireless.com/Default.aspx?Folder=\AirPrime\Open_AT_SDK_All_devices[/url]
Good luck.
Thanks a lot for these files. I tried to upload the .dwl file to the modem using the HYPETERMINAL
but the transfert is stopped; and I get a message from hyperterminal saying that the remote system stopped the transfert. May be this means that the file is not compatible with the modem version :question:
thanks lotam and gregorbader
