Error 812 with CPU WMP50
I try to open a ftp client with the following commands,
AT+WIPCFG=1 -> OK
AT+WIPBR=1,6 -> OK
AT+WIPBR=2,6,11,“xxxxxxxx” -> OK
AT+WIPBR=2,6,0,“xxxxxxxx” -> OK
AT+WIPBR=2,6,1,“xxxxxxxx” -> OK
AT+WIPBR=4,6,0 -> CME ERROR 812
I try to send SMS and everything is OK (the module works) but when I try the ftp software, I always had ERROR 812.
Do I need to do some setting ?
Can someone help me ?
Regards .
Stephane
Did you check your module is registered to the network?
CME ERROR 812 means “bearer connection failure : GPRS network failure”.
So i will suggest you to make sure your module’s registration status.
-Alex
Oups, I change my module’s registration and it work fine… thanks
But I have another problem ! I have a connection with my FTP server and I use the following command :
AT+WIPFILE=4,1,2,"./test.txt"
I have the anwser : CONNECT
And nothing else during long time and then
+CME ERROR 841.
On the server I have a text file (test.txt) but it is empty.
is someone have an idea ?
It seems some issue with your FTP connection… are you able to download files successfully from FTP?
-Alex
Yes, I try
AT+WIPFILE=4,1,1,"./test.txt"
And everything is ok. I can download the file on the SD card ??
Sorry I wrote too fast.
I have on my hyper terminal the following text but nothing on the SD card
OK<\r>AT+WIPFILE=4,1,1,"./test1.txt"
CONNECT
aazeertyuiop
qsdfghjklm
wxcvbn,;:!
123<
456
789
