Developer Studio compatibility problem
How to get rid of that problem?
please consider posting your questions regarding Legato on the dedicated forum (forum.legato.io)
For you particular problem, you need to make sure you’re using an SDK in line with the Legato version which is running on the device.
It’s true that latest SDK for WP85/WP75 is still based on Legato 16.10.3
But I suggest you to read at this post, that might be helpful for your use case: forum.legato.io/t/adding-newest- … tudio/2654
I just try and clean installation of Borland Developer Studio 2006 on Vista RC2 x64, after i install all the requirements ( .NET 1.1 sp1), and after logging the msi installation i always get :
InstallFiles: File: Borland.Delphi.dll, Directory: , Size: 102400
DEBUG: Error 2337: Could not close file: GetLastError:
DEBUG: Error 2835: The control ErrorIcon was not found on dialog SetupError
Internal Error 2835. ErrorIcon, SetupError
Internal Error 2337.
MSI (s) (6C:B8) [16:29:20:310]: Product: Borland Developer Studio 2006 – Internal Error 2337.
Thank you daav for your help
I got it to work!
If you’re still noticing a compatibility mode failure, I’d recommend using Regedit to explore your entire registry for “vm_web.exe” to see if there are other sections where that is being saved.
