SL8082T blocked and not responding
Developer Studio, Discovery Tool, Watcher
Postby CBaudouin » Tue Mar 21, 2017 4:33 pm
After having downloaded my own custom OpenAT program to the chip, it seems the SL8082T (in a Maestro Wireless M100 3G device) is blocked on a semaphore (error in the code). I cannot connect to the device through the serial port /dev/ttyS0. I get no response. Unplugging and replugging the device seems not to help.
Is there a procedure to reinitialize totally the chip ?
I have seen here: https://forum.sierrawireless.com/viewtopic.php?f=108&t=8126&hilit=semaphore that DWLWin could help me on that issue. Is the program compatible with my device ?
Thank you.
CBaudouin
Has thanked: 1 time
Have thanks: 0 time
Re: SL8082T blocked and not responding
Postby mlw » Wed Mar 22, 2017 4:45 pm
No DWLWin is not compatible with your unit, this is only for the old 2G ST based units.
You need to contact your distributor as there is a program around I think that can stop the application running by putting it into boot mode on power up through the USB.
For this post the author mlw
has been thanked by :
CBaudouin (Thu Mar 23, 2017 8:50 am)
mlw
Has thanked: 0 time
Have thanks: 71 times
Postby CBaudouin » Thu Mar 23, 2017 8:49 am
Thank you for your answer
I managed to resolve this problem. The AT command would not respond to commands like AT+WOPEN=0. But I found that the command AT+WDWL would be the only one to actually work. I sent the bootloader and firmware through XMODEM-K1 https://mycusthelp.net/SIERRAWIRELESS/_cs/AnswerDetail.aspx?sSessionID=&aid=487. The device is now functional again.
Thank you.
CBaudouin
Has thanked: 1 time
Have thanks: 0 time
Return to Development tools
Who is online
Users browsing this forum: No registered users and 2 guests
