SL8082T - SPI latency
Hi
There seems to be a latency issue with the SL8082T SPI bus service OAT library
The attached file is an example I captured on the SL8 SPI port - using the SPI sample (either sync or async methods have same issue).
with command at+read=FFFF,32 // no address with a byte opcode write followed by 32 byte read
[attachment=0]SL8082T SPI CS to CS.png[/attachment]
[attachment=1]SL8082T SPI 1 byte opcode and 32byte read .png[/attachment]
The clock speed is ~16MHz
The CE is low for 0.377ms
Between the write end and the read start is a delay of 0.198ms
Between the read finish and chip select high there is a delay of 0.15ms
I modified the sample to send multiple reads - one after the other. There is a 1.16ms delay between the 1st CS high and the next 2nd CS low.
These are very long delays
  • why is this?
  • is there anything I can do to reduce them?
The inter-byte read delay is low <0.16us
Thanks in advance
John
images are not visible. please post again…
Looks like this forum bug again: Uploads not working!
[FIXED] Forum attachements bug ← maybe not fixed…?
Hi
The files view fine on my machine so I suspect there is some issue with the forum - as a workaround the images are available here
https://www.dropbox.com/s/de5d8mscx6yt7qe/SL8082T%20SPI%201%20byte%20opcode%20and%2032byte%20read%20.png?dl=0
https://www.dropbox.com/s/n47wh2gauz66zbi/SL8082T%20SPI%20CS%20to%20CS.png?dl=0
This is using current released FW
R7.52.2.A5.201411281219
S4_1_0_21AP R2371 CNSHZ-ED-XP0031 2014/11/27
Cheers
John
