# XM0110 and Location Lib - GPS\_AIDING\_DEE\_WRITE\_ERROR
**URL:** <https://forum.sierrawireless.com/t/xm0110-and-location-lib-gps-aiding-dee-write-error/8375>\
**Category:** Open AT\
**Created:** [January 21, 2016, 12:19pm UTC](https://forum.sierrawireless.com/t/xm0110-and-location-lib-gps-aiding-dee-write-error/8375 "2016-01-21T12:19:53Z")\
**Posts on this page:** 3\
**Page:** 1
<div class="post-metadata">
**Author:** ![JSurf](https://sea1.discourse-cdn.com/flex025/user_avatar/forum.sierrawireless.com/jsurf/32/2243_2.png) [@JSurf](https://forum.sierrawireless.com/u/JSurf)\
**Post date:** [January 21, 2016, 12:19pm UTC](https://forum.sierrawireless.com/t/xm0110-and-location-lib-gps-aiding-dee-write-error/8375/1 "2016-01-21T12:19:53Z")
</div>
Hi All,
WMP100
FW:7.47.0
Location Lib:1.3.0.2
I’m getting the error “GPS\_AIDING\_DEE\_WRITE\_ERROR” in my gps aiding handler.
I receive my GPS\_AIDING\_DEE\_START\_EVT and then get this error about 15 seconds later.
Under what circumstances should I get this error from the DEE downloader? I’ve gone through the location development guide document and haven’t found anything to help narrow it down (hopefully I’ve just missed something).
```auto
gps_aidingSetOpts(GPS_OPT_AIDING_MODE, GPS_AIDING_MODE_DEE, GPS_OPT_AIDING_HANDLER,
                    pfk_gpsAidHandler, GPS_OPT_AIDING_DEE_DURATION, 3, GPS_OPT_AIDING_DEE_CMD, GPS_AIDING_DEE_CMD_NONE,
                    GPS_OPT_AIDING_DEE_SERVER_ADD, ServerIPAddress, GPS_OPT_AIDING_DEE_SERVER_PORT, ServerPort, GPS_OPT_AIDING_DEE_AUTH_CODE,
                    AuthCode, GPS_OPT_AIDING_DEE_SOCKET_TYPE, "TCP", GPS_OPT_AIDING_DEE_TIMEOUT, 10, GPS_OPT_END);
Thanks in advance.
**Post date:** [January 26, 2016, 1:54pm UTC](https://forum.sierrawireless.com/t/xm0110-and-location-lib-gps-aiding-dee-write-error/8375/2 "2016-01-26T13:54:08Z")
</div>
I have found that I get this error when I am unable to connect to the server.
This error code seems a little misleading, but anyway… this is now solved.
**Post date:** [June 6, 2016, 6:38am UTC](https://forum.sierrawireless.com/t/xm0110-and-location-lib-gps-aiding-dee-write-error/8375/3 "2016-06-06T06:38:46Z")
</div>
An FYI.
After chatting to Sierra Wireless, I found out this server is actually down. Still awaiting feedback as to why this server is no longer functioning.
In the meantime, I am simply forwarding all connections to this IP (on our private APN) to the server the HL6 is using.
