# wip\_bearerOpen returning WIP\_BERR\_BAD\_STATE
**URL:** <https://forum.sierrawireless.com/t/wip-beareropen-returning-wip-berr-bad-state/3517>\
**Category:** Open AT\
**Created:** [August 2, 2009, 2:10pm UTC](https://forum.sierrawireless.com/t/wip-beareropen-returning-wip-berr-bad-state/3517 "2009-08-02T14:10:22Z")\
**Showing post:** 12
**Author:** ![awneil](https://avatars.discourse-cdn.com/v4/letter/a/49beb7/32.png) [@awneil](https://forum.sierrawireless.com/u/awneil)\
**Post date:** [March 5, 2010, 7:45am UTC](https://forum.sierrawireless.com/t/wip-beareropen-returning-wip-berr-bad-state/3517/12 "2010-03-05T07:45:24Z")
Here’s a debugging suggestion:
Use the old TMT, and enable the ATI Level 1 Traces:
 ![](https://us1.discourse-cdn.com/flex025/uploads/sierrawireless/original/2X/a/ab83f23be4dccf8777118976ab982540438f0f91.gif)
(you can probably also do this in M2MStudio - I just don’t know how)
This will let you see the AT commands that WIP is using internally - and, most importantly, any error responses to those commands.
Also be sure that you’ve enabled all the WIP traces - see: [Multiple HTTP Requests - every other one fails](https://forum.sierrawireless.com/t/multiple-http-requests-every-other-one-fails/4184/1)
You should also check precisely what return code you’re getting from wip\_bearerStart - the ASSERT is just telling you that it’s neither OK nor WIP\_BERR\_OK\_INPROGRESS…
_[View the full topic](https://forum.sierrawireless.com/t/wip-beareropen-returning-wip-berr-bad-state/3517)._
