Wifi connect second Time
how to connect wifi second time??
I cannot connect until timeout.
this is my log file
dmesg.txt (24.8 KB)
no problem is found on my side.
you might need to type “app restart wifiService” between each wifi start.
command_line_for_wifi.txt (12.3 KB)
it mean I have to “wifi client stop” and then “app restart wifiService”.
so I connect to wifi again, right??
Use only this 2 line??
you can give a try on that
It’s not work. Should I have to do anything with “app runProc…” ??
Are we using same FW?
I have use Wp7605 with FW R13.2 SWI9X07Y_02.28.05.03
if you follow my command, what will happen?
