# Using AT\*AAFINSTALL to install AAF Lua app
**URL:** <https://forum.sierrawireless.com/t/using-at-aafinstall-to-install-aaf-lua-app/8711>\
**Category:** Development tools\
**Created:** [August 4, 2016, 4:57pm UTC](https://forum.sierrawireless.com/t/using-at-aafinstall-to-install-aaf-lua-app/8711 "2016-08-04T16:57:29Z")\
**Posts on this page:** 2\
**Page:** 1
<div class="post-metadata">
**Author:** ![gregsuzy](https://avatars.discourse-cdn.com/v4/letter/g/ec9cab/32.png) [@gregsuzy](https://forum.sierrawireless.com/u/gregsuzy)\
**Post date:** [August 4, 2016, 4:57pm UTC](https://forum.sierrawireless.com/t/using-at-aafinstall-to-install-aaf-lua-app/8711/1 "2016-08-04T16:57:29Z")
</div>
I am trying to use the AT\*AAFINSTALL command on the RV50 to install an AAF Lua application. I have an FTP server set up to put the application file on but I am not exactly sure what file type is expected by the RV50. I am using Developer Studio for ALEOS Version : 2.0.0.201310251637. I tried using the Export to Local Application Package and it created a tar file. I put the tar file on the ftp server and specified the exact file name in the AAFINSTAL command. The AAFINSTALL command failed to load this file. Should I be using one of the file included in the tar file instead? The only error message I get is “Cannot Load Application”
Greg Dunn
**Post date:** [August 4, 2016, 6:15pm UTC](https://forum.sierrawireless.com/t/using-at-aafinstall-to-install-aaf-lua-app/8711/2 "2016-08-04T18:15:18Z")
</div>
I think I figured out my problem. It seems like the HOST parameter must be specified as an IP address instead of URL. Also, specifying the filename.tar worked fine.
Greg Dunn
