then can the modemdemo work to make it establish data connection?
Hi @jyijyi
There has no modemDemo in my device.
so I should compile by myself then update it ?
yes, you need to compile it and run it
BTW, didn’t you already download to it before?
I reset my device, so I think it removed.
Hi @jyijyi ,
the command is worked, so how can I use it port the modemDemo to my APP ?
you need to understand the modemDemo program flow and copy the related to code to your application.
Hi @jyijyi ,
OK, I will try it, Maybe I will have problem then I will ask you again. Thanks for your help.
Hi @jyijyi ,
I try to use modemDemo method to create connection.
So my workflow is like below:
- le_mdc_SetPDP(profileRef, LE_MDC_PDP_IPV4)
- le_mdc_SetAPN(profileRef, “internet”)
- le_mdc_StartSession(profileRef)
- le_data_Request()
- set gateway and dns
- test connection.
I found connection will stop when app is stopped.
BTW, my app will stop by “exit(EXIT_SUCCESS)”
My question is that the connection will stop when app is stopped?
If you don’t add exit(), is it ok?
Maybe you can keep the app running
Hi @jyijyi
Yes, if I don’t add exit then the connection will keep.
It means my app should be running ?
I saw the modemdemo keeps running
Hi @jyijyi ,
OK I understood, Thanks for your help.
