Supreme 10 init
I need to initialize my new Fastrack Supreme 10 modem for smstools (smstools.meinemullemaus.de) under redhat.
can you provide me with the commands (AT+?) that i need in my smsd.conf in order to initialize the modem.
The modem should be blinking but there is a contant light on the modem…
Here is my /etc/smsd.conf:
devices = GSM1
logfile = /var/log/smsd.log
loglevel = 7
blacklist = /local/apps/smsgw/blacklist.txt
[GSM1]
device = /dev/ttyS0
mode = new
baudrate = 115200
incoming = yes
#init = AT+???
#init2= AT+???
Here is my /var/log/smsd.log
2008-10-10 15:03:56,2, smsd: Smsd v2.2.20 started.
2008-10-10 15:03:56,6, GSM1: Modem handler 0 has started.
2008-10-10 15:03:56,6, GSM1: Checking device for incoming SMS
2008-10-10 15:03:56,6, GSM1: Checking if modem is ready
2008-10-10 15:03:56,7, GSM1: -> AT
2008-10-10 15:03:56,6, smsd: outgoing file checker has started.
2008-10-10 15:03:56,7, GSM1: Command is sent, waiting for the answer
2008-10-10 15:03:56,7, GSM1: <- AT
2008-10-10 15:03:56,6, GSM1: Checking if Modem is registered to the network
2008-10-10 15:03:56,7, GSM1: -> AT+CREG?
2008-10-10 15:03:57,7, GSM1: <- AT+CREG?
+CREG: 0,0
2008-10-10 15:03:57,5, GSM1: Modem is not registered, waiting 10 sec. before retrying
Thanks in advance
~maymann
