Hi All,
I have implemented SSL to connect to a server.
I have tested and it works just fine to my server and that of a banking institution.
However, when connecting to another server, I always get a 302 found response.
I can connect via a web browser and it works fine.
I have even eliminated GPRS problems by connecting via an Ethernet interface, with the same results.
I suspect a strange SSL setting or similar.
I can see it connecting and doing the certificate transfer and cipher change etc. So it it talking, just the server kicks it out for some reason.
- Has anyone encountered this before?
- Is it possible when using https, to change the local (yes local) port? It appears to default to 1024, and I would like to bump it to something else above 50000.
Fastrack Extend - V7.46
tia
