SL8082T blocked and not responding
After having downloaded my own custom OpenAT program to the chip, it seems the SL8082T (in a Maestro Wireless M100 3G device) is blocked on a semaphore (error in the code). I cannot connect to the device through the serial port /dev/ttyS0. I get no response. Unplugging and replugging the device seems not to help.
Is there a procedure to reinitialize totally the chip ?
I have seen here: [url]https://forum.sierrawireless.com/t/no-port-communication/7402/1] that DWLWin could help me on that issue. Is the program compatible with my device ?
Thank you.
No DWLWin is not compatible with your unit, this is only for the old 2G ST based units.
You need to contact your distributor as there is a program around I think that can stop the application running by putting it into boot mode on power up through the USB.
Thank you for your answer
I managed to resolve this problem. The AT command would not respond to commands like AT+WOPEN=0. But I found that the command AT+WDWL would be the only one to actually work. I sent the bootloader and firmware through XMODEM-K1 https://mycusthelp.net/SIERRAWIRELESS/_cs/AnswerDetail.aspx?sSessionID=&aid=487. The device is now functional again.
Thank you.
