# Reverse Telnet/SSH Access Denied Non-Functional
**URL:** <https://forum.sierrawireless.com/t/reverse-telnet-ssh-access-denied-non-functional/9650>\
**Category:** AirLink routers\
**Created:** [November 28, 2017, 8:33pm UTC](https://forum.sierrawireless.com/t/reverse-telnet-ssh-access-denied-non-functional/9650 "2017-11-28T20:33:47Z")\
**Posts on this page:** 3\
**Page:** 1
<div class="post-metadata">
**Author:** ![derekyu](https://avatars.discourse-cdn.com/v4/letter/d/b77776/32.png) [@derekyu](https://forum.sierrawireless.com/u/derekyu)\
**Post date:** [November 28, 2017, 8:33pm UTC](https://forum.sierrawireless.com/t/reverse-telnet-ssh-access-denied-non-functional/9650/1 "2017-11-28T20:33:47Z")
</div>
I have been having trouble getting the Reverse Telnet/SSH function to work to be able to use the serial port to configure a legacy serial configurable device.
Device: MP70, ALEOS 4.8.1 BLD 006
I followed the instructions in the manual that are largely similar to the following online article:
[https://source.sierrawireless.com/resources/airlink/forum\_topics\_and\_questions/how-to-establish-a-reverse-ssh-to-a-serial-device-behind-the-airlink-device/](https://source.sierrawireless.com/resources/airlink/forum_topics_and_questions/how-to-establish-a-reverse-ssh-to-a-serial-device-behind-the-airlink-device/)
I set the serial port up as follows:
> Startup mode default: Reverse Telnet SSH
> Configure serial port: 115200,8N1
> Left all of the other settings at their default values which are the same as shown in the above article.
I set the SSH service up with the following parameters:
> Remote Login Server Mode: SSH
> Remote Login Server Telnet/SSH Port\> 2332
> Telnet/SSH Echo: Enabled
I tried to SSH locally (connected to the MP70 switch) into the gateway (192.168.13.31)and I can establish a connection using the “user” account and the default password “12345”. I am then presented with the AT command interface. So I know the SSH service is responding properly.
```auto
login as: user
user@192.168.13.31's password: //12345 typed at prompt
at
I then tried to SSH locally using the “sconsole” username and the default password of “12345” like the manual describes however, the SSH service responds with an access denied message.
```auto
login as: sconsole
sconsole@192.168.13.31's password: //12345 typed at the prompt
Access denied
Thinking that the password may have been inadvertently set to something else, I went to the Admin page and changed the “sconsole” password to “54321” and clicked _Change Password_. The page stated “Password changed successfully”.
```auto
login as: sconsole
sconsole@192.168.13.31's password: //54321 typed at the prompt
Access denied
However, I still get and “access denied” at the SSH prompt when using the “sconsole” username and the new or default passwords.
Any help would be appreciated. Thanks, Derek
**Author:** ![nlo](https://avatars.discourse-cdn.com/v4/letter/n/97f17d/32.png) [@nlo](https://forum.sierrawireless.com/u/nlo)\
**Post date:** [December 1, 2017, 11:18pm UTC](https://forum.sierrawireless.com/t/reverse-telnet-ssh-access-denied-non-functional/9650/2 "2017-12-01T23:18:32Z")
</div>
Hi derekyu,
I hate to be the bearer of bad news, but unfortunately, Reverse SSH is a feature that is bugged in 4.8.1. This is expected to be fixed in 4.9.0 which is right around the corner. Will you consider using Telnet instead? Of course, it’s not as secure, but it will get the job done until ALEOS 4.9.0 is out.
Regards,
Nick
**Post date:** [December 5, 2017, 7:34pm UTC](https://forum.sierrawireless.com/t/reverse-telnet-ssh-access-denied-non-functional/9650/3 "2017-12-05T19:34:48Z")
</div>
Thanks, I can wait for an update to ensure SSH works with the serial console. Good to know I wasn’t completely crazy.
Thanks, DY
