# Remote access to AceManager not working.
**URL:** <https://forum.sierrawireless.com/t/remote-access-to-acemanager-not-working/9687>\
**Category:** AirLink routers\
**Created:** [December 14, 2017, 12:35pm UTC](https://forum.sierrawireless.com/t/remote-access-to-acemanager-not-working/9687 "2017-12-14T12:35:49Z")\
**Posts on this page:** 5\
**Page:** 1
<div class="post-metadata">
**Author:** ![Jdrich](https://avatars.discourse-cdn.com/v4/letter/j/e47774/32.png) [@Jdrich](https://forum.sierrawireless.com/u/Jdrich)\
**Post date:** [December 14, 2017, 12:35pm UTC](https://forum.sierrawireless.com/t/remote-access-to-acemanager-not-working/9687/1 "2017-12-14T12:35:49Z")
</div>
I am trying to establish remote access to AceManager on an RV50. I have set up the address, and I am using IP manager and the [eairlink.com](http://eairlink.com) domain. I can connect to the web address both on http and https (with the default ports) on my browser while connected to the ethernet port, but not via the internet. I have set remote access to both http and https. I’m not sure what I’m missing here.
**Author:** ![Moderator1](https://avatars.discourse-cdn.com/v4/letter/m/9fc348/32.png) [@Moderator1](https://forum.sierrawireless.com/u/Moderator1)\
**Post date:** [December 19, 2017, 6:49am UTC](https://forum.sierrawireless.com/t/remote-access-to-acemanager-not-working/9687/2 "2017-12-19T06:49:28Z")
</div>
Please contact authorized distributor in SWI for your support to provide you the solution.
you can refer to below mentioned link to get the authorized distributor details.
[https://www.sierrawireless.com/distributor-page/#/](https://www.sierrawireless.com/distributor-page/#/)
Thanks and Regards,
Moderator
**Author:** ![douglasmsavino](https://avatars.discourse-cdn.com/v4/letter/d/2acd7d/32.png) [@douglasmsavino](https://forum.sierrawireless.com/u/douglasmsavino)\
**Post date:** [February 20, 2018, 4:32pm UTC](https://forum.sierrawireless.com/t/remote-access-to-acemanager-not-working/9687/3 "2018-02-20T16:32:24Z")
</div>
I have the same issue.
**Post date:** [February 20, 2018, 8:04pm UTC](https://forum.sierrawireless.com/t/remote-access-to-acemanager-not-working/9687/4 "2018-02-20T20:04:22Z")
</div>
In my case I was able to connect remotely using my laptop connected to an existing gateway via ethernet on the same network.
Verizon had assigned my RV50 up as a non public IP
**Author:** ![axelf911](https://avatars.discourse-cdn.com/v4/letter/a/8dc957/32.png) [@axelf911](https://forum.sierrawireless.com/u/axelf911)\
**Post date:** [February 23, 2018, 1:40am UTC](https://forum.sierrawireless.com/t/remote-access-to-acemanager-not-working/9687/5 "2018-02-23T01:40:35Z")
</div>
I had similar issues. First, make sure that VPN tunnel is turned off. Then make sure Remote Access (HTTP and HTTPS) is enabled for AceManager.
Originally, my SIM card APN settings did not allow me to have a static IP. Thus, my SIM card ended up with some weird local IPs that are probably routed by the Mobile network. When I got the proper APN settings allowing me to have a Static WAN IP, then the AceManager was accessible through the Static WAN IP.
