Random in C++
hi,
We want to write a random function in C++ language and put into a header file . But the copiler don’t recoginize the C++ language and show us error . I want to know if it eclipse support the C++ language ?
#ifndef AD_ADCHANDLER_H_
#define AD_ADCHANDLER_H_
#include <iostream>
#include <cstdlib>
ascii word[100];
void main(){
 srand((unsigned)time(/0));
    int random_integer;
        random_integer = (rand()%10)+1;
    switch(random_integer)
         case 0 :word[100]="+ADC: 4145,1393,1376\nOK";
         break;
         case 1 :word[100]="+ADC: 4140,1390,1375\nOK";
         break;
         case 2 :word[100]="+ADC: 4141,1395,1378\nOK";
         break;
         case 3 :word[100]="+ADC: 4146,1399,1372\nOK";
         break;
         case 4 :word[100]="+ADC: 4145,1393,1375\nOK";
         break;
         case 5 :word[100]="+ADC: 4142,1394,1376\nOK";
         break;
         case 6 :word[100]="+ADC: 4140,1393,1375\nOK";
         break;
         case 7 :word[100]="+ADC: 4145,1393,1378\nOK";
         break;
         case 8 :word[100]="+ADC: 4143,1399,1374\nOK";
         break;
         case 9 :word[100]="+ADC: 4145,1396,1378\nOK";
         break;
#endif /*AD_ADCHANDLER_H_*/
Is there any document we can get to be a reference for us?
Best Regards,
thia
The Open-AT SDK is specifically described and configured as an ANSI ‘C’ environment - not C++
There are plenty of threads on adapting Open-AT for C++ if you want to do it…
Eclipse is a general IDE - it can be configured for many different languages…
But why do you say you need C++ :question:
I don’t think there was anything in the code you posted that requires C++ rather than just ANSI ‘C’ - is there?
That is impossible.
You cannot write a truly random function in any programming language!
A programming language is a deterministic list of instructions - so it can never give a truly random output!
The best you can get is a pseudo-random output.
No, you should certainly not put the function itself into a header file! :open_mouth:
Doing that is a sure way to get lots of Linker errors - complaining about multiple definitions of your function(s) for every file that includes your header!
Only the function prototype should go in the header - the function itself should be in a separate source file and/or a library file
See: c-faq.com/decl/decldef.html
I’ve just received this in an email newsletter:
So, If you want to learn about Eclipse, why not take a look at some of these articles:
