Query on kernel crash
Looks like the 200 ms delay for control message during initialization fixed the initialization issue and 100 ms worked for run time. We are testing some stress test for long number of days.
What is the default factory data mode for EM7565 ? Is it Raw IP mode? Can it support Ethernet as well?
so far i only tried RAW IP mode only for the driver:
You can also see here where other user is using it as eth1 interface:
Thank you. Are you saying that default factory mode set on the radio is Raw IP?
I did not change anything setting and I compiled the driver in RAW IP mode and it works for me.
we also see the below error codes from SDK. Can you help to understand this and the effect of it for the connection. 2
SLQSGetSysSelectionPref failed, error code: 57348
SLQSNasSwiModemStatus failed, error code: 57348
you better open a new topic as this is not related to original topic
Thank you. I will create another topic.
Can you please provide your comments on the reason for the no kernel crash seen with control message delay of 100 ms and there is a crash seen with 200 ms delay. The crash seems to be random and sometime it comes in a day or sometimes after 1 week. Is this can affect the thread timing and expose a race condition?
i have no idea on this.
But by default of the driver, it already uses 100ms, so better follow the default driver.
Thank you, we will test with default value then.
