# Query on kernel crash
**URL:** <https://forum.sierrawireless.com/t/query-on-kernel-crash/36103>\
**Category:** Uncategorized\
**Created:** [September 11, 2026, 9:27pm UTC](https://forum.sierrawireless.com/t/query-on-kernel-crash/36103 "2026-09-11T21:27:48Z")\
**Showing post:** 38
**Post date:** [October 15, 2026, 8:06am UTC](https://forum.sierrawireless.com/t/query-on-kernel-crash/36103/38 "2026-10-15T08:06:37Z")
you can use AT!SCACT=1,1 to establish data connection
> [@Example on establishing data connection by AT!SCACT via MBPL R20 driver](https://forum.sierrawireless.com/t/example-on-establishing-data-connection-by-at-scact-via-mbpl-r20-driver/24130):
> Here is an example to establish data connection by AT!SCACT via MBPL R20 driver: Module: WP7609 FW: R13 MBPL: R20 PC Environment: Ubuntu 18 need to install the MBPL R20 driver for qmi\_wwan and qcserial (MBPL\_Drivers\_USB\_R20\_ENG1-src.tar.gz) avoid the Ubuntu changing the network name: ln -s /dev/null /etc/systemd/network/99-default.link sudo apt-get install libqmi-utils sudo apt-get install udhcpc now insert the USB to PC sudo chmod 777 /sys/class/net/wwan0/qmi/raw\_ip …
you need to first narrow down what factor makes the crash
If you confirm it is caused by slqssdk, you can consider using AT!SCACT or latest version of slqssdk
_[View the full topic](https://forum.sierrawireless.com/t/query-on-kernel-crash/36103)._
