Greetings.
I´m trying to calculate the RSA signature with the following expression:
s = m^d mod n
So, d and n are 1024 bits numbers, they are bignums.
I´m using two aproaches for doing this calculations:
- Function ngcBNModExp.
- Function ngcRSA_mod_exp.
But for both functions i´m having an ARM Data Access exception, and a WatchDog reset. I´m using Q2687G module with Security Lib version 1.5.
The following is the data and the code I´m using for the first function. For the second function the code is similar but look at this first:
unsigned char n[] = { 0xE7, 0x00, 0x49, 0x42, 0xC2, 0x5E,
0xBB, 0x8B, 0x93, 0x0D, 0x23, 0xE8, 0x7A, 0xBD, 0xEF, 0x10, 0xD6, 0xBA,
0xCF, 0x93, 0x2D, 0x46, 0xB1, 0x36, 0xF3, 0x51, 0x32, 0xBF, 0x87, 0xED,
0x5B, 0x7A, 0x0A, 0x63, 0x81, 0xA8, 0xA8, 0x46, 0x1F, 0xA7, 0x68, 0xBE,
0x25, 0x16, 0x49, 0xD9, 0x99, 0x91, 0xEA, 0x28, 0xFC, 0xCD, 0x5F, 0x62,
0x79, 0x5D, 0x26, 0x86, 0x34, 0xE3, 0x30, 0x96, 0x8D, 0x1C, 0x52, 0xA8,
0xC1, 0x4B, 0x14, 0xDD, 0xFD, 0x34, 0x1D, 0x0B, 0x92, 0xC5, 0xD6, 0x3C,
0xBF, 0xE8, 0xCE, 0x30, 0xBE, 0x0F, 0xD0, 0xB0, 0xB4, 0x06, 0xAD, 0x38,
0xD3, 0x4B, 0x7E, 0x2C, 0x6D, 0x65, 0xB1, 0x39, 0x51, 0xF9, 0x93, 0x47,
0x21, 0xEE, 0x9C, 0xDA, 0xBB, 0xD8, 0x3D, 0x4D, 0x0B, 0x3B, 0x38, 0x0F,
0x39, 0x17, 0x2A, 0x63, 0x41, 0x58, 0x9D, 0x9B, 0xA3, 0x62, 0x3F, 0x04,
0x6D, 0x0B, 0x1B, 0xD1, 0x6A, 0x3B, 0xF6, 0x83, 0xA3, 0xC6, 0x80, 0x7D,
0xF0, 0xF1, 0xDF, 0x1F, 0x2F, 0x62, 0x06, 0xA2, 0xFE, 0xA4, 0x9C, 0xD8,
0xDB, 0x45, 0x0E, 0x88, 0x75, 0x13, 0xDA, 0x04, 0x7A, 0x66, 0x84, 0xEB,
0x31, 0x52, 0x46, 0x75, 0xE8, 0xE1, 0xDB, 0xF1, 0x08, 0x3C, 0xF6, 0x72,
0xA6, 0x38, 0x21, 0x5D, 0x2A, 0x0C, 0x33, 0x08, 0x44, 0x54, 0x24, 0xC7,
0x4F, 0xC2, 0xE5, 0x50, 0xA3, 0x53, 0x96, 0x87, 0x51, 0x7C, 0x18, 0xFA,
0xF7, 0xD5, 0x8A, 0xB7, 0xFA, 0x74, 0x4A, 0x00, 0xE8, 0xB0, 0x73, 0x17,
0x67, 0xC5, 0x2A, 0xC8, 0xFE, 0x7B, 0x5D, 0x7E, 0xAD, 0x63, 0x29, 0x21,
0x60, 0x7D, 0xA0, 0x9D, 0xE9, 0x36, 0x63, 0xE5, 0xA9, 0x92, 0x36, 0x9F,
0x87, 0xF3, 0xFB, 0xEF, 0xA0, 0x77, 0x57, 0x89, 0x71, 0xC0, 0x9F, 0xBC,
0x6E, 0x55, 0x09, 0x9E, 0x8D, 0xC0, 0x8C, 0x5B, 0xFD, 0x2D };
unsigned char d[] = { 0xDC, 0x08, 0x38, 0xC0, 0x3F, 0x56,
0x6E, 0xFC, 0x06, 0xE9, 0x18, 0x50, 0x04, 0x42, 0x50, 0xAA, 0x50, 0x6F,
0x06, 0xF3, 0xA0, 0xC7, 0xDA, 0x5B, 0x86, 0x2E, 0xCC, 0xD1, 0x05, 0x8F,
0x80, 0x77, 0xE1, 0xD7, 0x60, 0x94, 0x9F, 0x1C, 0x94, 0x60, 0x28, 0xF4,
0x1D, 0x6D, 0x7A, 0x90, 0xAB, 0xA8, 0x02, 0x4C, 0x62, 0x68, 0xD9, 0x37,
0x7A, 0x74, 0xD1, 0x12, 0x3A, 0xE4, 0x40, 0xCE, 0xD6, 0xC0, 0xA8, 0xB7,
0x97, 0xCE, 0x85, 0xA4, 0xE1, 0xDF, 0x36, 0xDF, 0x64, 0x41, 0xCF, 0xCC,
0x73, 0xDC, 0x34, 0x32, 0xD7, 0x87, 0x46, 0xF8, 0x59, 0xB2, 0x96, 0x63,
0x2F, 0x58, 0x94, 0x69, 0x8B, 0x16, 0xB7, 0x55, 0xEB, 0x10, 0x78, 0x49,
0xE4, 0x37, 0x5D, 0xEF, 0x37, 0xC8, 0x44, 0xB3, 0xD3, 0x43, 0xE8, 0x25,
0x0F, 0xF3, 0x51, 0xEB, 0xD3, 0x3D, 0xAE, 0x7A, 0xA6, 0x89, 0x19, 0x8F,
0x84, 0xB0, 0xA5, 0xD8, 0xFD, 0xCF, 0x7A, 0xD1, 0x42, 0x03, 0xB5, 0x92,
0x0C, 0xF0, 0x9A, 0x03, 0xFA, 0x97, 0x7B, 0x09, 0x84, 0x63, 0x26, 0x4F,
0x6D, 0x5B, 0x21, 0x22, 0xD3, 0x5A, 0x4A, 0x60, 0x5A, 0x5E, 0x31, 0x34,
0xCE, 0xD0, 0x42, 0x3A, 0x20, 0x40, 0x80, 0x8E, 0x63, 0x57, 0xF1, 0x44,
0x1F, 0x89, 0x30, 0x25, 0xAA, 0x57, 0x86, 0x1C, 0x88, 0xCF, 0x87, 0xA8,
0xE5, 0x11, 0x7D, 0x56, 0xCA, 0x1F, 0x48, 0xA7, 0x7B, 0xA0, 0x1E, 0x37,
0xD9, 0x3C, 0x2B, 0x4C, 0x8F, 0xAC, 0x2E, 0x8D, 0x96, 0xC0, 0x34, 0x32,
0xB6, 0xA0, 0x6F, 0x13, 0x6E, 0x72, 0xE7, 0x68, 0x29, 0x4E, 0x2F, 0x7B,
0x18, 0x71, 0x02, 0x25, 0x2E, 0x1C, 0x59, 0x2E, 0x60, 0x79, 0x06, 0x24,
0x98, 0x76, 0x92, 0xE0, 0x41, 0x0A, 0x75, 0xF7, 0x1F, 0xEF, 0x90, 0x7A,
0xB9, 0xEF, 0xAB, 0x3E, 0xE7, 0x05, 0x58, 0x14, 0x4A, 0x61 };
unsigned char block[] = { 0x00, 0x01, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,
0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,
0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x00, 0x30, 0x21,
0x30, 0x09, 0x06, 0x05, 0x2B, 0x0E, 0x03, 0x02, 0x1A, 0x05, 0x00, 0x04,
0x14, 0x2E, 0x98, 0x6D, 0x96, 0xCF, 0x38, 0x82, 0x6F, 0x8B, 0x0E, 0x8C,
0xC0, 0x41, 0x29, 0x21, 0x19, 0x2A, 0x8E, 0xC4, 0x50 };
NGCbnctx *ctx;
ctx = ngcBNCtxNew((void *) NULL);
if (ctx == NULL)
TRACE((DS_ERROR_TRACE_LEVEL, "Context is null!" ));
TRACE((DS_SUCCESS_TRACE_LEVEL, "RSA test" ));
NGCbignum * pre_encry = ngcBNNew ( ctx->heap );
NGCbignum * _n = ngcBNNew ( ctx->heap );
NGCbignum * _d = ngcBNNew ( ctx->heap );
NGCbignum * _s = ngcBNNew ( ctx->heap );
if (pre_encry == NULL ||
_n == NULL ||
_d == NULL ||
_s == NULL )
TRACE((DS_ERROR_TRACE_LEVEL, "All or more than one bignum variable is null!" ));
pre_encry = ngcBNbin2bn ( block, sizeof(block), pre_encry );
_n = ngcBNbin2bn ( n, sizeof ( n ), _n );
_d = ngcBNbin2bn ( d, sizeof ( d ), _d );
TRACE((DS_SUCCESS_TRACE_LEVEL, "Loaded RSA variables!" ));
TRACE((DS_SUCCESS_TRACE_LEVEL, "ngcBNModExp ..."));
ngcBNModExp(_s, pre_encry, _d, _n, ctx);
TRACE((DS_SUCCESS_TRACE_LEVEL, "Done!"));
Any help would be really appreciated.
Thanks in advance,
Sebastián Villa
SYTECSA
