# Problem starting apps
**URL:** <https://forum.sierrawireless.com/t/problem-starting-apps/12025>\
**Category:** Uncategorized\
**Created:** [April 14, 2015, 10:55am UTC](https://forum.sierrawireless.com/t/problem-starting-apps/12025 "2015-04-14T10:55:48Z")\
**Posts on this page:** 3\
**Page:** 1
<div class="post-metadata">
**Author:** ![danielgomezdn](https://avatars.discourse-cdn.com/v4/letter/d/f9ae1b/32.png) [@danielgomezdn](https://forum.sierrawireless.com/u/danielgomezdn)\
**Post date:** [April 14, 2015, 10:55am UTC](https://forum.sierrawireless.com/t/problem-starting-apps/12025/1 "2015-04-14T10:55:48Z")
</div>
I have a problem with one of my applications. I don’t know why but when I try to start the application from my host: startapp MyApp 192.168.1.2 or when I try to start the application in the target (directly): app start MyApp I always receive the same error:
```auto
root@swi-mdm9x15:~# app start MyApp
Starting app 'MyApp'...
There was an error. Application 'MyApp' could not be started.
But I can start the application through the Developer Studio (connected by ssh). After that, I can execute always MyApp with the startapp & app start commands
Is it an application or a command problem? Which is the difference executing startapp/app start/Start application (devstudio)?
Daniel
**Author:** ![daav](https://sea1.discourse-cdn.com/flex025/user_avatar/forum.sierrawireless.com/daav/32/2767_2.png) [@daav](https://forum.sierrawireless.com/u/daav)\
**Post date:** [April 15, 2015, 7:50am UTC](https://forum.sierrawireless.com/t/problem-starting-apps/12025/2 "2015-04-15T07:50:26Z")
</div>
Your application was probably created through Developer Studio, which added a line to the ADEF file requiring a binding for a potential core file.
This binding can be resolved only if a temporary /tmp/ds/yourapp/core file is created before your app is started. This is managed when DS starts the app, but not if you start it manually.
But with Legato 15.01 this binding became useless since now the core files are written in /tmp/legato\_logs directory, so you can safely remove it from the ADEF file.
Note that the operation to add this binding at project creation will be cleaned out in DS 3.4
**Post date:** [April 16, 2015, 3:30pm UTC](https://forum.sierrawireless.com/t/problem-starting-apps/12025/3 "2015-04-16T15:30:19Z")
</div>
Hi daav,
I didn’t know the meaning of /tmp/ds//core so, thank you for the explanation.
I’ve tried to remove and now I’m able to run the application remotly so it works.
Thank you for your support,
Daniel
