Printing from M2MStudio
I can’t seem to see any options for controlling print output; eg
Font size;
Headers & Footers;
Margins;
Line Wrapping;
etc, etc,…
window -> preferences -> general -> editors -> text editors
(found by typing “print” in the search box in preferences)
(nothing on headers btw)
-edit-
and this seems like a eclipse problem again, since they can’t seem to support it in linux, it’s removed from the entire eclips-package.
window -> preferences -> C/C++ > Code Style
and then click on ‘Edit’.
You can manage ‘Line wrapping’ for instance.
window -> preferences -> General > Appearance > Color and Fonts > C/C++
It’s possible to set your own font here.
Different locations to play with these settings :cry:
The only option I see there is a single “margin” setting - presumably the right-hand margin?
Ah - didn’t realise that was a “search” box!
:blush:
Do they also apply to printing, or just the on-screen editor?
yes I confirm that they (line wrapping and font settings) also apply to printing after some tests.
That’s not much good - the print & screen sizes should be independent.
Still no sign of headers & footers, then…?
Good resolution of the day: Eclipse helps you to reduce printing :slight_smile:
sarcastic mode
Eclipse, the all-in-one productivity killer :stuck_out_tongue:
end sarcastic mode
