# No registration with EM7340 with specific SIM
**URL:** <https://forum.sierrawireless.com/t/no-registration-with-em7340-with-specific-sim/9381>\
**Category:** MC/EM Series\
**Created:** [July 31, 2017, 12:43pm UTC](https://forum.sierrawireless.com/t/no-registration-with-em7340-with-specific-sim/9381 "2017-07-31T12:43:47Z")\
**Posts on this page:** 10\
**Page:** 1
<div class="post-metadata">
**Author:** ![ginzler](https://avatars.discourse-cdn.com/v4/letter/g/3da27b/32.png) [@ginzler](https://forum.sierrawireless.com/u/ginzler)\
**Post date:** [July 31, 2017, 12:43pm UTC](https://forum.sierrawireless.com/t/no-registration-with-em7340-with-specific-sim/9381/1 "2017-07-31T12:43:47Z")
</div>
I have a strange behavior of our EM7340 modules when used in combination with a specific SIM card. With one SIM card, LTE registration works fine with the other no registration is possible. Both SIM cards work in other devices (Huawei MediaPad M3 and OnePlus 3). The SIM cards are custom configured and from different vendors. The non-working one is a Gemalto UpTeq Multimedia Ready V.2, the working one is a Anritsu SIM of unknown exact type. I used also qmicli to query various information from the card but could not find a difference between the cards or error indication. Is there any way to find out why the EM7340 does not register?
Known good registration with SIM2:
```auto
ati
Model: EM7430
Revision: SWI9X30C_02.24.05.06 r7040 CARMD-EV-FRMWR2 2017/05/19 06:23:09
MEID: 35907506040317
IMEI: 359075060403176
IMEI SV: 12
FSN: LR709406530310
+GCAP: +CGSM
at!gstatus?
!GSTATUS:
Current Time: 36 Temperature: 32
Reset Counter: 7 Mode: ONLINE
LTE band: B28 LTE bw: 10 MHz
LTE Rx chan: 9260 LTE Tx chan: 27260
LTE CA state: NOT ASSIGNED
RRC state: RRC Connected
IMS reg state: No Srv
PCC RxM RSSI: -62 RSRP (dBm): -80
PCC RxD RSSI: -50 RSRP (dBm): -67
Tx Power: 0 TAC: 0001 (1)
RSRQ (dB): -6.0 Cell ID: 01A2D101 (27447553)
SINR (dB): 28.2
No registration with SIM1:
```auto
at!gstatus?
!GSTATUS:
Current Time: 68 Temperature: 30
Reset Counter: 6 Mode: ONLINE
System mode: LTE PS state: Not attached
LTE Rx chan: 9260 LTE Tx chan: 4294967295
EMM state: Deregistered Waiting for PDN
RRC state: RRC Idle
PCC RxM RSSI: -56 RSRP (dBm): -80
PCC RxD RSSI: -44 RSRP (dBm): -67
RSRQ (dB): -5.8 Cell ID: 01A2D101 (27447553)
SINR (dB): 27.6
**Author:** ![mlw](https://sea1.discourse-cdn.com/flex025/user_avatar/forum.sierrawireless.com/mlw/32/3706_2.png) [@mlw](https://forum.sierrawireless.com/u/mlw)\
**Post date:** [August 1, 2017, 8:15am UTC](https://forum.sierrawireless.com/t/no-registration-with-em7340-with-specific-sim/9381/2 "2017-08-01T08:15:16Z")
</div>
I am guessing that the unit is in Australia given that you are on band 28? No matter.
Try the below commands to see if you can get an error cause out of the unit, it will also give a bit more information about what is around it.
```auto
ati
at+cmee=1
at+cpin?
at+cimi
at+cops?
at+cops=?
at+cops=1,2,"xxxxx",7
In the above the xxxxx is the MNC and MCC returned by the cops=? command before it.
**Post date:** [August 1, 2017, 12:17pm UTC](https://forum.sierrawireless.com/t/no-registration-with-em7340-with-specific-sim/9381/3 "2017-08-01T12:17:35Z")
</div>
Thanks for your answer. The behavior is the same with B7.
```auto
ati
Model: EM7430
IMEI SV: 12
FSN: LR709406530310
+GCAP: +CGSM
at+cmee=1
at+cpin?
+CPIN: READY
at+cimi
001010001
at+cops?
+COPS: 0
at+cops=?
+cops: (1,"lorem","lorem","00101",7),(3... ---snip---
at+cops=1,2,"00101",7
It then hangs. I cancelled it after 30 minutes.
**Post date:** [August 1, 2017, 12:25pm UTC](https://forum.sierrawireless.com/t/no-registration-with-em7340-with-specific-sim/9381/4 "2017-08-01T12:25:47Z")
</div>
That ones difficult to figure out as we would need to be able to see the layer 3 messaging between the unit and the network (might be a SIM thing as well). If you are doing this on Linux you need to use the dmcapture tool that comes with the QMI SDK (its only a bash script, you don’t need to run QMI to take the log file) or SWILog with Windows.
You then need to pass it back through your commercial/support channel for them to be analysed with the QC tools.
**Post date:** [August 1, 2017, 5:18pm UTC](https://forum.sierrawireless.com/t/no-registration-with-em7340-with-specific-sim/9381/5 "2017-08-01T17:18:50Z")
</div>
```auto
./dmcapture.sh -l -d /dev/ttyUSB0 -o log.txt
Does not produce any log and log.txt remains at 0 bytes. I followed the SDK guide and compiled the gobinet and gobiserial modules with debug enabled and did the checks described. The devices and interface are operational. The documentation available on this tool is very limited. It seems just to dump the DM serial port outputs. But the port seems silent even if the card is transferring data and having successful registration. I could not find the SWILog inside the Windows driver directory nor on the website, where can I find it?
**Post date:** [August 2, 2017, 12:43pm UTC](https://forum.sierrawireless.com/t/no-registration-with-em7340-with-specific-sim/9381/6 "2017-08-02T12:43:05Z")
</div>
Second time lucky writing a response to the posting.
The reason you are not seeing anything come out is because I do not think you are applying a filter using the -f switch, there is a sub directory to the dmcapture one giving some of the common ones, the standard one though that i think you need is ‘MC7xxx\_GSM\_GPRS\_EDGE\_WCDMA\_LTE\_DATA\_EVDO\_SMS.sqf’.
So the test procedure should be
1. Power unit up let it enumerate.
2. Set to low power mode with at+cfun=0
3. Start logging using something like
```auto
./dmcapture -d /dev/ttyUSB0 -f filter/MC7xxx_GSM_GPRS_EDGE_WCDMA_LTE_DATA_EVDO_SMS.sqf -o logfile.raw
4. Set to full power mode with at+cfun=1
5. Recreate the issue.
6. Set to low power mode (at+cfun=0).
7. Stop the logging.
This should result in a log file that can be converted (you will not see anything in it which is decipherable) and analysed.
**Post date:** [August 3, 2017, 12:35pm UTC](https://forum.sierrawireless.com/t/no-registration-with-em7340-with-specific-sim/9381/7 "2017-08-03T12:35:27Z")
</div>
Thank you for your support. I was able to fix the issue. It was due to the APN Access List (ACL) file on the SIM. Some devices seem to ignore it, so they work. Not sure if the EM7340 respects this field or how it reacts on it. I think the field was properly defining a “default” APN which in turn should work. But maybe it was malformed. When the ACL is disabled via the UST or EST, everything is fine.
**Post date:** [August 3, 2017, 12:39pm UTC](https://forum.sierrawireless.com/t/no-registration-with-em7340-with-specific-sim/9381/8 "2017-08-03T12:39:22Z")
</div>
Wow that’s low level, thanks for letting me know as its a new one on me. Who helped you figure it out in the end? Or did you figure it out yourself?
**Post date:** [August 4, 2017, 12:54pm UTC](https://forum.sierrawireless.com/t/no-registration-with-em7340-with-specific-sim/9381/9 "2017-08-04T12:54:49Z")
</div>
We have test equipment here and luckily able to figure it out ourselves. Do you know how the EM7340 is designed to handle this SIM card setting?
**Post date:** [August 14, 2017, 11:19am UTC](https://forum.sierrawireless.com/t/no-registration-with-em7340-with-specific-sim/9381/10 "2017-08-14T11:19:37Z")
</div>
I’m afraid I do not it would require a level of knowledge that probably only exists within Qualcomm (and some log files).
