i use the sample by changing the APN USER PWD IP PORT, it works well. but i revamped the program , that i input the APN USER PWD IP PORT, the program is not working properly,and the error is following :
what can i do for the error ?
THX .
THX .
Can you please try to create TCP client using WIPSOFT commands(using same APN USER and PASSWORD) and check if client is created or not ? In case of failure please enable the CME ERROR and check what is the exact CME ERROR number received(to analyze the cause of failure i.e. host unreachable).
Thanks.
i see , the ISP has problem …ha ha ha
