Hi, I downloaded a copy of the iOS sample app code from
https://bitbucket.org/bluecreation/melodysmart-ios-swift/src/master/
As I follow the instruction to run carthage update to install the app. However, I am getting the following error
******* Cloning MelodySmartKit
A shell task (/usr/bin/env git clone --bare --quiet https://github.com/BlueCreation/MelodySmartKit.git failed with exit code 128:
remote: Repository not found.
fatal: repository ‘https://github.com/BlueCreation/MelodySmartKit.git/ ’ not found
Do you know where is the source code of MelodySmartKit moved or how I can install and run the sample app?
–Wallace
Donald
February 24, 2020, 3:04am
2
Hi @wjyzhang
Sierra Wireless released MelodySmartKit Sample App iOS:
https://source.sierrawless.com/resource/airprime/application_notes_and_code_samples/melodysmartkit-sample-app-ios/#sthash.FKdpkUyv.dpbs
How to install the MelodySmartKit iOS Sample App:
Copy
Install [Carthage] (https://github.com/Carthage/Carthage )
Run update carthage
Pulling .framework is built in the project
Run the application
But the source code https://github.com/Carthage/Carthage has been deleted.
Please contact your reseller or distributor directly for this case.
Hi Donald, I just tried. I think this repo is deleted,
https://github.com/BlueCreation/MelodySmartKit/
Carthage is still there,
So since Sierra Wireless acquired BlueCreation, I thought Sierra Wireless would host the source code for MelodySmartKit in a different repo. Without it I cannot compile the sample iOS app.
–Wallace
Donald
February 24, 2020, 8:18am
4
Hi @wjyzhang
Yes, This repo is deleted.
Please contact your reseller or distributor directly for technical support in this case.
