# MC7455 Verizon roaming problem
**URL:** <https://forum.sierrawireless.com/t/mc7455-verizon-roaming-problem/9574>\
**Category:** MC/EM Series\
**Created:** [October 26, 2017, 6:44pm UTC](https://forum.sierrawireless.com/t/mc7455-verizon-roaming-problem/9574 "2017-10-26T18:44:56Z")\
**Posts on this page:** 3\
**Page:** 1
<div class="post-metadata">
**Author:** ![DmitriK](https://avatars.discourse-cdn.com/v4/letter/d/b782af/32.png) [@DmitriK](https://forum.sierrawireless.com/u/DmitriK)\
**Post date:** [October 26, 2017, 6:44pm UTC](https://forum.sierrawireless.com/t/mc7455-verizon-roaming-problem/9574/1 "2017-10-26T18:44:56Z")
</div>
I have two RevC MC7455 modules one with older SWI9X30C\_02.20.03.22\_00\_VERIZON\_002.026\_001 firmware and one with the latest SWI9X30C\_02.24.05.06\_00\_VERIZON\_002.034\_000.
I have verizon sim card with static address and I am trying to roam from Canada. Roaming fails as LTE connection cannot be established and attempt to roam in WCDMA fails with a verbose call end reason 239.
Any suggestions on what causes this problem and how to resolve it?
RevB MC7455 with an older firmware (SWI9X30C\_02.05.07.00\_VERIZON\_002.008\_003) has no problem establishing LTE connection from the same location using same antenna and same SIM card.
Best regards
Dmitri
**Post date:** [October 27, 2017, 12:39pm UTC](https://forum.sierrawireless.com/t/mc7455-verizon-roaming-problem/9574/2 "2017-10-27T12:39:55Z")
</div>
Hi
I downgraded FW on the rev C modem to the same version as rev and still have no luck. I cannot get an LTE connection with Verizon image. Genric image works fine in LTE
I verified pdp settings on both modems and they seem to be correct.
rev b pdps
at+cgdcont?
+CGDCONT: 1,“IPV4V6”,“ne01.vzwstatic”,“0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0”,0,0,0,0
+CGDCONT: 2,“IPV4V6”,“vzwadmin”,“0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0”,0,0,0,0
+CGDCONT: 3,“IPV4V6”,“ne01.VZWSTATIC”,“0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0”,0,0,0,0
+CGDCONT: 4,“IPV4V6”,“vzwapp”,“0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0”,0,0,0,0
+CGDCONT: 5,“IPV4V6”,“vzw800”,“0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0”,0,0,0,0
+CGDCONT: 6,“IPV4V6”,“vzwenterprise”,“0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0”,0,0,0,0
rev C pdps
at+cgdcont?
+CGDCONT: 1,“IPV4V6”,“ne01.VZWSTATIC”,“0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0”,0,0,0,0
Output of at!gstatus? for both modems looks like this
Rev B
AT!GSTATUS?
!GSTATUS:
Current Time: 24 Temperature: 24
Reset Counter: 1 Mode: ONLINE
LTE band: B2 LTE bw: 15 MHz
LTE Rx chan: 875 LTE Tx chan: 18875
LTE CA state: INACTIVE
RRC state: RRC Idle
IMS reg state: No Srv IMS mode: Normal
PCC RxM RSSI: -74 RSRP (dBm): -101
PCC RxD RSSI: -95 RSRP (dBm): -140
Tx Power: 0 TAC: 2D8A (11658)
RSRQ (dB): -8.7 Cell ID: 01D0FB28 (30473000)
SINR (dB): 21.8
at!gstatus?
!GSTATUS:
Current Time: 280 Temperature: 25
System mode: LTE PS state: Not attached
LTE band: B5 LTE bw: 5 MHz
LTE Rx chan: 2585 LTE Tx chan: 4294967295
EMM state: Deregistered Limited Service
RRC state: RRC Idle
PCC RxM RSSI: -66 RSRP (dBm): -89
PCC RxD RSSI: -101 RSRP (dBm): -138
RSRQ (dB): -8.5 Cell ID: 01D0FB46 (30473030)
SINR (dB): 21.8
Looks like something is missing in configuration to make a connection to the Verizon network.
Dmitri
**Author:** ![allanfolz](https://avatars.discourse-cdn.com/v4/letter/a/d2c977/32.png) [@allanfolz](https://forum.sierrawireless.com/u/allanfolz)\
**Post date:** [December 8, 2017, 7:53pm UTC](https://forum.sierrawireless.com/t/mc7455-verizon-roaming-problem/9574/3 "2017-12-08T19:53:41Z")
</div>
Hello Dmitri,
Remember me from this thread? [https://forum.sierrawireless.com/t/mc7354-on-verizon-network/8821/1](https://forum.sierrawireless.com/t/mc7354-on-verizon-network/8821/1)
Heh. It’s been a long time, no?
I’m still on the MC7354, so may not apply to you, but what I discovered was that the “IPV4V6” contexts don’t reliably work with our IPV4 stack. What I’ve found to work is change context 1 to “IP”, then enable context 10 & 11 – on the MC7354 those are already type “IP”. YMMV. Good luck. Let me know how it goes.
```auto
AT+CGDCONT?
+CGDCONT: 1,"IP","vzwims","0.0.0.0",0,0 <-- by default this will be "IPV4V6"
+CGDCONT: 2,"IPV4V6","vzwadmin","0.0.0.0",0,0
+CGDCONT: 3,"IPV4V6","VZWINTERNET","0.0.0.0",0,0
+CGDCONT: 4,"IPV4V6","vzwapp","0.0.0.0",0,0
+CGDCONT: 5,"IPV4V6","vzw800","0.0.0.0",0,0
+CGDCONT: 6,"IPV4V6","vzwadmin","0.0.0.0",0,0
+CGDCONT: 9,"IPV6","vzwims","0.0.0.0",0,0
+CGDCONT: 10,"IP","vzwadmin","0.0.0.0",0,0
+CGDCONT: 11,"IP","VZWINTERNET","0.0.0.0",0,0
+CGDCONT: 12,"IPV4V6","vzwapp","0.0.0.0",0,0
+CGDCONT: 13,"IP","","0.0.0.0",0,0
