Yes, I read the document a little while struggling with this step Install below MBPL R20 USB driver for qmi_wwan and qcserial by “make” and “make install”
Then have you installed the driver?
Trying using SDK oem@lamhas-pro:~/Downloads/MBPL_SDK_R35_ENG4-lite.bin/SampleApps/lite-qmi-connectionnnection-managerhostx86_64
lite-qmi-connection-manager v1.0.2308.1
Open transport “/dev/cdc-wdm5” on USB device in QMI mode
Interface id: 0x8
InitializeRegularService eWDA failed.EnableQmap failed.
InitializeRegularService eDMS failed.
you need to get a linux engineer to work on driver and SDK
I tried SDK it is not connecting the modems and compiling giving an error
make -C /lib/modules/6.5.0-18-generic/build/ M=/home/oem/Downloads/bin/Ubuntu_x64/5.3.0-55-generic/
make: Entering directory ‘/usr/src/linux-headers-6.5.0-18-generic’
warning: the compiler differs from the one used to build the kernel
The kernel was built by: x86_64-linux-gnu-gcc-12 (Ubuntu 12.3.0-1ubuntu1~22.04) 12.3.0
You are using: gcc-12 (Ubuntu 12.3.0-1ubuntu1~22.04) 12.3.0
scripts/Makefile.build:41: /home/oem/Downloads/bin/Ubuntu_x64/5.3.0-55-generic/Makefile: No such file or directory
make[2]: *** No rule to make target ‘/home/oem/Downloads/bin/Ubuntu_x64/5.3.0-55-generic/Makefile’. Stop.
make[1]: *** [/usr/src/linux-headers-6.5.0-18-generic/Makefile:2039: /home/oem/Downloads/bin/Ubuntu_x64/5.3.0-55-generic] Error 2
make: *** [Makefile:234: __sub-make] Error 2
make: Leaving directory ‘/usr/src/linux-headers-6.5.0-18-generic’
If you help to understand the error
Are you able to compile the usb driver?
If you see the document, you can use at!scact command to establish data connection
Yes , actually [MBPL_DRIVERS_R35_ENG4-bin.tar](javascript:void(0)
[gz] 644KB does not have the make file so I downloaded the [MBPL_DRIVERS_R35_ENG4-usb-src.tar](javascript:void(0)
[gz] 25KB that does have the make file and able compile and install the driver now working on 6. Use minicom to type AT command through /dev/ttyUSB2
AT!GSTATUS? should return network registered
oem@lamhas-pro:~/Downloads/USB/usb$ sudo at!scact
-bash: !scact: event not found
You need to use minicom to enter AT command
$ minicom
Here seems you can create the wwan interface:
does the qmi_wwan loaded?
Have you set up correctly for the APN in AT+CGDCONT?
what is the return of AT!GSTATUS?
Is it the same for MC7430?
BTW, you should enter AT!SCACT=1,1
total 3 modems installed in the computer MC7304 & MC7430 modems
Feb 23 21:48:18 lamhas-pro kernel: [ 80.669712] rfkill: input handler disabled
Feb 23 21:48:29 lamhas-pro kernel: [ 91.206907] audit: type=1107 audit(1708705 109.173:54): pid=743 uid=102 auid=4294967295 ses=4294967295 subj=unconfined msg= ‘apparmor=“DENIED” operation=“dbus_method_call” bus=“system” path=“/org/freedes ktop/PolicyKit1/Authority” interface=“org.freedesktop.DBus.Properties” member=“G etAll” mask=“send” name=“:1.11” pid=2083 label=“snap.snap-store.ubuntu-software” peer_pid=868 peer_label=“unconfined”
Feb 23 21:48:29 lamhas-pro kernel: [ 91.206907] exe=“/usr/bin/dbus-daemon” sa uid=102 hostname=? addr=? terminal=?’
Feb 23 21:48:29 lamhas-pro kernel: [ 91.207258] audit: type=1107 audit(1708705 109.173:55): pid=743 uid=102 auid=4294967295 ses=4294967295 subj=unconfined msg= ‘apparmor=“DENIED” operation=“dbus_method_call” bus=“system” path=“/org/freedes ktop/PolicyKit1/Authority” interface=“org.freedesktop.PolicyKit1.Authority” memb er=“CheckAuthorization” mask=“send” name=“:1.11” pid=2083 label=“snap.snap-store .ubuntu-software” peer_pid=868 peer_label=“unconfined”
Feb 23 21:48:29 lamhas-pro kernel: [ 91.207258] exe=“/usr/bin/dbus-daemon” sa uid=102 hostname=? addr=? terminal=?’
Feb 23 21:48:29 lamhas-pro kernel: [ 91.209305] audit: type=1107 audit(1708705 109.173:56): pid=743 uid=102 auid=4294967295 ses=4294967295 subj=unconfined msg= ‘apparmor=“DENIED” operation=“dbus_method_call” bus=“system” path=“/org/freedes ktop/PolicyKit1/Authority” interface=“org.freedesktop.DBus.Properties” member=“G etAll” mask=“send” name=“:1.11” pid=2083 label=“snap.snap-store.ubuntu-software” peer_pid=868 peer_label=“unconfined”
Feb 23 21:48:29 lamhas-pro kernel: [ 91.209305] exe=“/usr/bin/dbus-daemon” sa uid=102 hostname=? addr=? terminal=?’
Feb 23 21:48:29 lamhas-pro kernel: [ 91.209540] audit: type=1107 audit(1708705 109.173:57): pid=743 uid=102 auid=4294967295 ses=4294967295 subj=unconfined msg= ‘apparmor=“DENIED” operation=“dbus_method_call” bus=“system” path=“/org/freedes ktop/PolicyKit1/Authority” interface=“org.freedesktop.PolicyKit1.Authority” memb er=“CheckAuthorization” mask=“send” name=“:1.11” pid=2083 label=“snap.snap-store .ubuntu-software” peer_pid=868 peer_label=“unconfined”
Feb 23 21:48:29 lamhas-pro kernel: [ 91.209540] exe=“/usr/bin/dbus-daemon” sa uid=102 hostname=? addr=? terminal=?’
Feb 23 21:48:30 lamhas-pro kernel: [ 92.662999] audit: type=1400 audit(1708705 110.629:58): apparmor=“DENIED” operation=“open” class=“file” profile=“snap.snap- store.ubuntu-software” name=“/etc/appstream.conf” pid=2083 comm=“snap-store” req uested_mask=“r” denied_mask=“r” fsuid=29999 ouid=0
you need to add question mark in AT!GSTATUS?
What is the problem now?
wwan0 is not created?
why you have some many cdc-wdm interface?
Can you just connect one module to avoid confusion?
Can you post the kernel log once you connect the module to the host?
